Home > Technical > Phone Problem
XUJG
Phone Problem
Hi
I made a call via Bluetooth and since hanging up the system seems to be stuch with the number on the screen with the handset logo flashing.
The phone used is an approved model with the latest software.
I have tried turning the vehicle off for several hours but the number remains on the screen.
This will not allow the radio or CD to work.
I have tried to get into the reset menue by pressing the button on the end of the indicator stalk but that will not opperate the menu.
I have even tried to reset the system with the door key but that has no effect either.
Any ideas?
Regards
John
Post #81134 Wed Feb 07 2007 2:42pm
If you simply want to rectify the present situation disconnect the cars battery. This is a new problem to me and might just be a one off! 2005 Zambezi TDV6 - Gone but not forgotten
Post #81140 Wed Feb 07 2007 2:46pm
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
VA is almost right, but you have to reconnect the battery afterwards Laughing Laughing Laughing some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #81142 Wed Feb 07 2007 2:51pm
Otherwise your next post will be... "I can't start the car" Laughing
Post #81146 Wed Feb 07 2007 2:56pm
Thud Thud Rolling with laughter 2005 Zambezi TDV6 - Gone but not forgotten
Post #81147 Wed Feb 07 2007 2:57pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
Can we assume you have switched the phone off too so there is no connection to the car over BT?
Can you make another call via BT? Does it clear the screen doing it that way? L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #81162 Wed Feb 07 2007 3:13pm
Ring yourself! 2005 Zambezi TDV6 - Gone but not forgotten
Post #81164 Wed Feb 07 2007 3:15pm
XUJG
I had thought of disconnecting (and then reconnecting) the battery but need to look in the manual for the bonnet catch first!
It did occur to me that this may creat some problem elsewhere such as the alarm or tracker so am reluctant at the mo if there is another fix.
The phone wont reconnect at all it seems just the car is jammed up.
i have turned the phone off totally but no difference.
There must be a reset somewhere, unless of course that is the battery!
Post #81166 Wed Feb 07 2007 3:18pm
RRUK
Do you have the voice activated PTI?
If so, ask the voice system to "Phone dial number" and then try and dial something.
See if it unlocks it. L319 D4 HSE
1982 Series 3 SWB
Post #81168 Wed Feb 07 2007 3:19pm
There may well be, but disconnecting/reconnecting the battery should sort you out as long as you disconnect - pause - reconnect and don't leave it disconnected for any appreciable length of time.
Oh, and the bonnet catch is in the pax footwell, not the manual Wink
Post #81170 Wed Feb 07 2007 3:20pm
XUJG
Tha Battery did it ok
Thanks for your help. i will update this thread if it should happen again.
Regards
John
Post #81213 Wed Feb 07 2007 4:15pm
