Home > Tips & Tricks > Get warmer quicker, stay hotter and save fuel |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 |
leaving the AC compressor turned off will eventually lead to bacteria growing on the evaporator - this leads to a smelly socks / cabbage smell and 'could' lead to infections too (I didn't say that right ) |
Thu Feb 01 2007 6:14pm |
aam1234 Member Since: 08 Aug 2006 Location: Somewhere out there Posts: 450 |
One needs to turn on the A/C once a month or so even in winter, otherwise the compressor might get dry. This is what I heard, I could be wrong. |
Thu Feb 01 2007 6:30pm |
tf9 Member Since: 07 Jun 2006 Location: Moscow, Russia Posts: 643 |
Correct. No need to have AC on during the winter. ECON saves about 2-3l/100km! 2014 Mercedes-Benz S500 2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony 2013 BMW 530d 2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD 2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD 2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD. |
Thu Feb 01 2007 6:35pm |
Hi tf9,
Thu Feb 01 2007 6:58pm |
Hey
Thu Feb 01 2007 7:09pm |
Cool (literally)
Thu Feb 01 2007 7:24pm |
Cliff H Member Since: 03 Dec 2005 Location: uk Posts: 3233 |
There is a mod to make the temperature more accurate as you may find that you are forever turning up the temp on a longer run just to keep warm.
Thu Feb 01 2007 8:14pm |
Yeah... noticed that one... I start the ride with 20c and then end it with like 22-23c 2014 Mercedes-Benz S500 2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony 2013 BMW 530d 2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD 2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD 2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD. |
Thu Feb 01 2007 8:18pm |
This is the TSB for the 'sock' I should think it is the same for the D3 and RRS though you would have to check this.
Thu Feb 01 2007 8:23pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Cool thanks for that info Cliff RRS TDV6 Gone but still around
Fri Feb 02 2007 12:15am |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 |
I leave mine on all year 'round.., just doing my bit for global warming!!! |
Fri Feb 02 2007 12:26am |
Your bit to it up!!
Fri Feb 02 2007 12:28am |
How dare you, i'm a greenpeace adept and you are shocking me 2014 Mercedes-Benz S500 2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony 2013 BMW 530d 2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD 2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD 2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD. |
Fri Feb 02 2007 12:29am |
See your doing your bit as well with your green cars TF9!! RRS TDV6 Gone but still around
Fri Feb 02 2007 12:31am |
