![]() | Home > General > RR Sport roof aerial |
If you have the sat nav option you will get the fin. 2005 Zambezi TDV6 - Gone but not forgotten
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
I thought the aerial/fin was primarily for the Sat Nav.
Not sure about the 2007 model, but for the 2006 model neither the S nor the SE gets the roof fin by default as both the PTI and SatNav are options. The roof fin is used for both the SatNav and the PTI as far as I'm aware, so if you spec either you should get the roof fin.
No sat Nav - no fin! You can fit the fin, some come up on ebay for about £70.00 2005 Zambezi TDV6 - Gone but not forgotten
But if you spec PTI and use a cradle, do you not get the external aerial facility? (Regardless of whether you spec SatNav or not) |
Not sure. 2005 Zambezi TDV6 - Gone but not forgotten
WOODY179 Member Since: 30 Nov 2005 Location: Derbyshire Posts: 163 ![]() ![]() |
My first D3 only had the Premium sat nav and did not have the fin but my present D3 has both the premium sat nav and the pti kit which means I have the fin on the roof. However the external arial is only used if you use the cradle.
Hmm... where's TB when you need him? |
The fin picks up the GPS for the sat nav and like shmoogle said unless you use the cradle with the PTI you don't use the fin!
aam1234 Member Since: 08 Aug 2006 Location: Somewhere out there Posts: 450 ![]() ![]() |
Hi guys,
Did you spec PTI? If you did, then you have it.
Cool, thanks. I'll try that in a bit. |
shaun_ Member Since: 24 Jan 2007 Location: Victoria, Canada Posts: 93 ![]() ![]() |
my 07 has the fin and the bluetooth is always on...you have to set your phone to search for a new device, then it'll pop up as LAND ROVER then you pair it with 2121.. 2007 RRS HSE Java/Ebony w/Luxury Package
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
Here I am ![]() Right then, where do I start? There are a few people getting a little confused by the sounds of things. aam1234 - The easiest way of telling if your vehicle has the PTI installation is by looking at your steering wheel. If it has the red and green telephone paddle switches on the righthand side of the centre boss, you have PTI. No switches - no PTI. Any vehicle which has satnav or PTI will have a roof fin. But as some of you have already said, the phone aerial will only work if you are using the phone cradle in the cubby box lid. Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass. __________________ Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!! |
