![]() | Home > Technical > ACC/Front Winch Compatibility |
| TJ101 Member Since: 17 Jan 2007 Location: Somerset UK Posts: 207
Evening All,,
TJ101 - I think they might be telling the truth. I can see why it would disrupt the ACC in the same way that the bush bars do. 2005 Zambezi TDV6 - Gone but not forgotten
Hi VA, Yep found that post, so why then,when LR Fitted out the G4,S did they put the ACC system on, and not the standard Cruise ?? |
No idea - maybe they were too lazy to chance the ECU! 2005 Zambezi TDV6 - Gone but not forgotten
Anyway I think the Adaptive CC is fun for the first 1000 miles but I know a few owners have got p***ed off with the thing - too sensitive especially when you pass large coaches = sudden loss of speed. 2005 Zambezi TDV6 - Gone but not forgotten
| Pelyma Member Since: 28 Sep 2005 Location: Sussex Posts: 1497
Im pretty sure TFC has front sensors with the winch, if memory serves me correctly it knocks 2 sensors out but not all. TJ101 are you someone else on LROI forum? |
The sensors arn't the problem, you're right 2 should work if programmed correctly. The ACC is the problem. 2005 Zambezi TDV6 - Gone but not forgotten
Not bothered with the ACC system !!, but cruise would be handy, with a trip to the prynees coming up ! 997 TT, RR TDV8 Vog SE 90 V8 Hybrid www.wessex4x4response.org.uk http://forum.innovate4x4.com G4 RRS Gone |
TCF ?? another member ? The dealer is telling me, the winch is in the place of the sensors ?? so whats behind the box on the lh side ?? Have asked the dealer to speak to Special vehicles, also got customer relations to speak to the dealer as no one seams to be talking to each other Pelyma,, no, not i, not on LRO much,, LR4X4, is better for me www.wessex4x4response.org.uk http://forum.innovate4x4.com G4 RRS Gone |
| Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662
Pelyma - you're confusing PDC with ACC - the ACC (adaptive cruise control) uses a radar unit in the lower front grille opening of the RRS which is probably blocked by the winch fitment |
Correct Martin, the sensor is to the r/h side of the winch,as you look at it,
The radar probably has a wide angle sensor, and would pick up radar reflections straight off the winch. The ACC would probably think that you're a couple of inches from the car infront |
or relocate it under the bumper somehow! 2005 Zambezi TDV6 - Gone but not forgotten
Well. i could as last restort,,
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944
If that doesn't work, could they just take out the ACC module and restore the
| All times are GMT |
