![]() | Home > Technical > Suspention squeek |
| The doc Member Since: 31 Oct 2006 Posts: 1173
S E T F I R E to it |
That's a really useful bit of help Doc!
| tomi.omni Member Since: 12 Jan 2007 Location: Dubai Posts: 3
Hi Doc,
It will be burning if it doesn't start working |
| Huggy Bear Member Since: 27 Jan 2006 Location: Midlands Posts: 2
tomi - can often be the rear suspension joints that are in the rear knuckle that squeak (water can get in them and wash all the grease out). Worth a look if you ever take the wheel off - it is difficult to see them otherwise. The way I have found to check is to open the tailgate and jump up and down on the rear of the boot floor. If the suspension squeaks, then it is probably these. ===============================
| ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823
Unfortunately cannot afford an RRS(!), But I get to borrow my Boss's LR3 and RRS!
| TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927
Especially if you jump up and down in the rear loadspace. |
| homeins Member Since: 13 Jan 2007 Location: NORTH WEST LANCASHIRE Posts: 18
mine is to and it sounds like thhe engine is about to drop out like yours its a first addition model v8 all singing and dancing but why should it have this problem surrley tis is a re call ? |
| Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902
its not a recall situation - recalls are for 'Safety Critical' issus |
| RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2589
had my suspension bushes replaced at the front due to an inferior bushing used in early production models.
| All times are GMT |
