Home > General > SUSPENSION PROBLEM - SOUNDS LIKE A U/S SHOCK ABSORBER...
Page 9 of 15 <123 ... 8910 ... 131415>
rrsjo
QQUESTION:-
So if DR has been fitted on the Supercharged model and also offered as an option on other models since the introduction of the RRS, why are there not more complaints circulating about what Land Rover say is "just the standard noise the ARC valve makes and therefore not a fault"?
ANSWER:-
The amount of noise emitted by the ARC valve must differ from one vehicle to another! On some cars it cannot be heard at all, but on others it varies from "noticeable" to "untolerable" for the owner. Even VOR recognised a variation exists from one car to another.
OR
As some cars without DR fitted also report knocking from the front suspension, at least some of the dealers are wrongly diagnosing a knocking noise as being attributable to the ARC valve and are using the TB issued by LR to do nothing about it - eh Doc!
If this is the case, then LR and the dealers need to investigate reports of front suspension noises properly. If the cause is something other than the ARC valve, then the dealer should be able to correct the fault. If the noise is indeed the ARC valve, then the dealer should submit and Electronic Quality Report to LR. Then when LR recieve sufficient reports to trigger action, a solution should be found.
At the moment all front suspension complaints from owners appear to knocked back by the dealer on the basis of LR's Technical Bulletin stating knocking emitted by the front suspension is normal and not a fault.
Here's my solution Mr LR:- How about fitting an accoustic hood around the valve to deaden the noise?
Post #71238 Sun Dec 17 2006 6:13pm
The doc
"At the moment all front suspension complaints from owners appear to knocked back by the dealer on the basis of LR's Technical Bulletin stating knocking emitted by the front suspension is normal and not a fault."
how true Whistle
Post #71242 Sun Dec 17 2006 6:29pm
hartleyhair
Just for info:
I took my TDV8 out this afternoon specifically to listen for the knocking sound and to test the general handling. Couldn't hear anything unusual.
Didn't have that problem on my (non DR) last RRS either after 14500 Miles.
Only covered 750 miles in this one though.
Paul Driving - TDV8 HSE in Stornaway / Ebony / Brunel
Sold - 56 TDV8 HSE in Java Black EBONY/RHODIUM/PRIVACY GLASS
Sold - 05 TDV6 HSE BONATTI/BLACK/RHODIUM 20''STORMERS, PTI AND FACTORY TINT.
Post #71257 Sun Dec 17 2006 8:53pm
welsh alex
Kaine wrote:
FYI, my 07MY HSE does not make any knocking noise
nor mine - touch wood!
Post #71276 Sun Dec 17 2006 10:43pm
BoldlyGo
Nor mine, no knocks at all and I've now done 11,000 miles in the most comfortable, eye-catching legend of a car that I've ever driven. Ner Ner
I've got 3 mates with a Disco3, RRS supercharged and a HSE -- all 06 build - and they've got no knocks either !!!
9 pages of chat Fellas !!! Wow, I might even convince myself that i've got knocks if this carries on !! Wink P400e HSE Portofino Blue and Ivory Seats.. it's like a yacht!!
Lexus traded in ..a total piece of crap
Boldly now acquired - a Lexus RX 450hL
BoldlyGone...Sep 15 MY16 RRS SDV6, HSE, Barolo Black, Espresso/Almond interior.. Best car ever & Drop dead gorgeous... sadly with fuel dilution headaches that became intolerable
Arrived 2014. Oct - Lemoned March 2015- RRS SDV6 HSE
Boldly Gone = Sold for 14k via Pistonheads - 2006 TDV6 SE Buck Blue/Almond int
Post #71289 Sun Dec 17 2006 11:39pm
The doc
This is all good news!
If you had it you would know it - If mine is indeed the noise in question Question Question
Post #71292 Mon Dec 18 2006 12:45am
Brocklebank
Has eveyone who has this knocking noise had it from new or is it something which has developed over aperiod of time?
My car was perfect for the first 4k miles.
Doc, I do hope yours NOT the noise and is somthing for which a cure is found. Problem is, you will always be listening for it to reappear as the suspension 'knock'.
Post #71310 Mon Dec 18 2006 9:33am
The doc
I hope they can fix it too!
It was 100% not there until the lowering thing in IOM
Post #71326 Mon Dec 18 2006 10:22am
MAC
United Kingdom 2011 Range Rover Sport SDV6 HSE Orkney Grey
Just been driving a loan 07 HSE from my dealer. There is no indication of the knocking that is so appartent on mine.
Surely LR cannot explain this total difference as manufacturing variation. I have the loan vehicle for a couple of days so I will keep you updated. It will be interesting to get the dealer comments when I return it.
DOC - look forward to the outcome of your dealer visit.
Post #71339 Mon Dec 18 2006 11:02am
The doc
"DOC - look forward to the outcome of your dealer visit."
Me too!
They gave me a FREELANDER FFS - your lucky fella!
Post #71366 Mon Dec 18 2006 1:24pm
The doc
Milestone Milestone Milestone Milestone Milestone Milestone Milestone Milestone Milestone
I Collected my car today at 4pm from HILLENDALE in NELSON (FAB GUYS - THANKS AGAIN) and guess what????
NO knocking sound!
They replaced the Anti roll bar drop link bushes which were U/S - and that’s it - no excuses - no LR said - Just drop it of and they fix it!
I was so please I went on a 4 hour tour through Manchester etc to find all the potholes that I could and NO KNOCKING!
So...
The knocking sound on my car sounded like...
du du du du dump - long and drawn out over holes etc this is the noise it made when knocking was there.
du dump (the normal noise as the front and rear wheels hit the holes etc now)
Does this help ANYONE?
Thanks goes to AUTOLINES for suggesting Hillendale LR - I 'd have sold the car if it were not for Hillendale - and thanks to all you guys that have helped and supported me - now its time to sort the rest of you out!
I absolutely without reservation recommend and will be buying my next LR from:
HILLENDALE LR Nelson
www.hillendale.co.uk
Tel 01282723723
Steve Marsden on Service knows all about it and was really helpful!
AND FFS steer well clear of the chiseling tw8ts at:
JAMES EDWARDS St Helens or Chester as there Censored hawks.
Post #71438 Mon Dec 18 2006 9:29pm
Thats great news Doc - did they give you any explaination of what actually was faulty?
Post #71441 Mon Dec 18 2006 9:34pm
The doc
Anti roll bar drop link bushes were knackered!
Post #71443 Mon Dec 18 2006 9:36pm
your RRS is new though - correct? why were they no good - bad assembly?
Post #71444 Mon Dec 18 2006 9:39pm
The doc
They did not say Confused
I'll call tomorrow and find out Wink
Post #71445 Mon Dec 18 2006 9:42pm
