![]() | Home > Maintenance & Modifications > RRS and D3 suspension upgrades from Germany |
This month's LROI has an item about suspension upgrades for RRS and D3 made by a German company called Matzker. The test that Ed Cobley did on a d3 was quite startling and the suspension can be made to raise a further 50mm over standard offroad height and can also lower it 35mm BELOW normal for high speed stability. The same upgrade can be made to an RRS. There is also an engine tuning upgrade which raises the power out put of the TDv6 to 223bhp from standard 190 and 500Nm of torque, 60 more than standard. The Suspension upgrade also reprogrammes Active Roll Mitigation and progressively stiffens that suspension as speed rises, it is also adaptive so it learns from your driving style.............
| Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662
Some of the Matzker kit looks impressive, but at a price. Some of the other kit (there was a demo D3 at the Malvern LRO show earlier in the year) was a bit oddly designed, but good to have it on the market.
| Driller Member Since: 18 Aug 2006 Location: Perth Posts: 80
If you are after a translation, albeit a shoddy one, just google danzker and then hit the translate option next to the web page |
| XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894
Matzker does quality stuff !
| Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330
Got the gist of it using freetranslation.com - I like that lowering by 23mm when on the motorway which they claim reduces air resistance and handling when driving on "kurvigen" country roads (automated translation is NOT an exact science). I'd get more use from that than the extra 26mm in height.
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944
This is the first module I see that actually raises suspensions a bit more for offroading. There are many modules out there already lowering them somewhere between normal and access height for onroad driving, but this one is definitely more useful if you take it offroad. I wonder how it works, via an extra switch on the dash or through the existing suspensions switch (adding a couple of extra "stops" in addition to access, normal and offroad, that would be nice.) Expensive unit, though.
The problem I see with raising the suspension to super-extended mode is that if you get stuck then the vehicles got no more to give |
My understanding (from reading the German site, which isn't easy) is that the suspensions would raise somewhere above offroad mode (26 mm over) but not all the way to the maximum extended mode - and viceversa when lowered on the freeway, down 20 mm which is about 1/2 way between normal and access... So it sounds as if there would be some extra travel still available. |
| Cornelius Vermuyden Member Since: 15 Aug 2006 Location: The Far Canal Posts: 190
JE can, as usual, do better. 235bhp and 575 Nm, all for a measly £685 +VAT Can't be bad |
I'm quite happy the the original power and torque, but the extra height would be useful offroad, I'm not sure that I would use the super low setting either.
i talked to a german LR official yesterday and he confirmed that the car garanty doesnt get affected when you install Matzker parts - he has a very good reputation in Germany.
| MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598
Hmmmm Does this open the door for for tuners to be "approved" by LR
" WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
There was another thread here about the suspension lowering at 100 mph which everyone seemed to think was insane...however - listening to a German colleague who translated the Matzker information about their suspension kit - they state that the car lowers when travelling at a constant 100 KPH - they mention this in describing the features of their kit.
i go read it laterz - but i think it was that you could driver lowered all the time without attempting 100 kph.
| All times are GMT |
