![]() | Home > General > Accepting deposits - L320 Backseat map light kits |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 524
Looking at T’s tracking he had his three days after arriving at customs, so potentially you’ll have it Friday or Saturday. It just arrived at customs around 8pm last night, should hopefully clear today and be on its merry way to you. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
I’ve had a couple couple questions regarding bulbs. To get it out of the way these kits come with standard incandescent bulbs, there are just too many options and people may have already upgraded so not going to try to predict that nor will it help the price.
| Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 429
"If you’re looking to change to LED, be sure to look at the actual construction and not just be wowed that it has 1,000 SMD LED chips all over it. By the way, the Osram LEDs (both) only pull about 1w which will cause issues with the front door under mirror and under door lights. They will need load resistors to function correctly. This is how I did it for my under door lights:"
I’m saying the Osram LEDs because they only draw 1w. The front door modules look for around a 3w draw from the door indicators, under door lights and under mirror lights. If the draw is too low it shuts them off. So that means your LEDs must be close to or over 3w. The Chinese things in the pics would work, but not the Osrams, had to have load resistors for them to come on. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
I use PIAA (Japanese) LED bulbs and they have a high enough resistance built-in that they will work on any CANBUS system without installing any inline resistors.
| All times are GMT |
