![]() | Home > General > 06 4.4 HSE Heater matrix question.... |
| abeachsoul Member Since: 28 Jun 2012 Location: London Posts: 17
So I just cracked on with this and sorted it in the end - only took about 30 mins from start to finish.
| pbonaceto Member Since: 23 Dec 2016 Location: Boston, MA Posts: 1
Thank you for the in-depth explanation with photos! I will be attempting to replace my heater core matrix soon in my 2009 RRSPT HST and this will be extremely helpful. If you happen to remember, where did you source the new heater core matrix? It appears to that it will likely have much better flow than the original and probably last significantly longer....
| Flatty7 Member Since: 19 Oct 2015 Location: Essex Posts: 11
So pleased I’ve just found this thread! Was contemplating a massive full dashboard out job!
| Davebc Member Since: 12 Jul 2015 Location: Kelowna BC Posts: 38
Great write up thank you. Has anyone tried replacing the heater matrix on a left hand drive RRS? I’m mid job and having issues with the glove box assembly-looks like more stuff to remove and/or undo to access the upper clamps where pipes join before bulkhead. Any help much appreciated. 2007 Stornaway Grey RRS HSE 4.4 V8 |
| Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 359
I just flushed mine sorted it out in 5 minutes |
| MrClarkyy Member Since: 30 Oct 2025 Location: West Yorkshire Posts: 4
I'm pretty sure it is the same try flushing and or reversing the flow and return pipes |
| All times are GMT |
