![]() | Home > General (L494) > ACE problems |
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 331 |
So the codes indicate pressure loss at the front and rear anti rolls.
| Greeny11 Member Since: 29 Oct 2025 Location: England Posts: 9 |
The only fluid loss is when it overflows the reservoir and starts spilling from the tank. The valve block was a genuine new part which has since been removed.
So the fluid is coming out the reservoir with the cap screwed on? |
Yes that's correct. Currently the tank empties when starting the engine and fills back to the min max lines when you shut off |
There's something wrong with the lines/fluid flow as the tank shouldn't empty.
PS When it empties have you tried filling it back up (whilst its running) - it sounds like the fluid is not getting around the system - possible air lock somewhere. |
I will try this. There is plenty of air bubbling out into the reservoir when the engine is running. Thank you very much for your help so far. I will try filling whilst the engine is running. If this doesn't work, perhaps a vacuum fill is the only way forward |
Sounds like youve got an airlock somewhere - fill it back up when it empties then put it in dynamic mode if you can and drive round a few roundabouts on full lock this will get the anti roll bars moving and it should self bleed.
Thats great info. Thanks! Can I presume that if I get hold of SDD and carry out that bleed procedure, if my valve block is dead the car presumably will not perform the rocking motion. Just wondering if its worth trying this before fitting another new valve block. |
Yes correct it wont initiate the bleed procedure. I think most newer AUTEL/Snap Ons have the bleed procedure in the modules also.
| Woppyman Member Since: 08 Jul 2015 Location: England Posts: 78
Great advice and I concur. You need to open the solenoids and pressure by-pass in the valve block to do a proper bleed. This won't happen unless you use a tool to put the ACE system into bleed mode. Its a great system until you need to crack it open. Also the workshop manual says the system is EXTREMELY sensitive to contamination so watch you don't get any rust or dust particles in the fluid. MY20 L494 4.4 A/B Chipped Indus Silver
Ok so using an Autel MK908, Ive put the system in to automatic bleed. The car however does not move at all. Lots of aerated oil throthing around in the reservoir.
Does the bleed system operate on the Autel - like start and finish as it would give an error that it cant start due to a fault code.
The car shouldn't move, but it is quite an involved procedure to get this right. I think it sounds like you need to follow step by step, maybe a couple of times. Workshop manual as below;
MY19 Velar D300 Dynamic Chipped Indus Silver Evoque HSE Dynamic Santorini Black MY12 L320 5.0 Supercharged A/B Indus Silver |
| All times are GMT |
