![]() | Home > Technical > L320 2012 Tailgate open warning - can't lock vehicle |
| drexal Member Since: 17 Dec 2019 Location: london Posts: 121
Hi all,
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5155
There are several options for the tailgate in the CCF files, but none appear to mention turning off any warnings, only a thought but could you loosen the hinges slightly and flex the tailgate enough to latch correctly, only thing is if that did work whether it would release again, if not would probably be in bigger mess than ever, could possibly remove the tailgate lower trim panel first which might allow you to get to the latch from inside the car if it did, as I say only a thought though.
Hey Col,
| JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 435
Just thinking outside the box. To my mind the hinges are very strong and it would take a lot to bend them. Could it be that the actual plate area the hinges mount to are bent ? Bear in mind the hinges bolt into sheet metal, albeit probably with a reinforcing plate behind the panel that the bolt threads go into.
Hi, Insurance here is not to bad, works out about the equivalent of £800.00 sterling fully comp. but pay a bit extra as have a agreed value if car is totalled. One of the most stupid thing here is you don't even have to have insurance not even third party. Just done the registration (UK Ved) for the year cost $140.00 (£70). I probably only do around 4/5K a year these days so can't really see any point in replacing it, does everything I want, long bought and paid for and it's never let me down, not even a flat battery, apart from annual services the only thing the engine has had is alt/supercharger belts and sparkplugs at 7 year service, only suspension bushes it has had is front lower arms and bolts and the was due to a leaking hydro bush initially, obviously had discs and pads etc. and a few other bit's but not much. Cheers Col |
Hi guys,
Glad you got it sorted and thanks for the update and thanks ! |
Hey all,
No longer an RRS owner as I'm now full
Hey JonnyCJ
Sorry - didn't realise what year yours was. Try popping your query into CoPilot and giving it as much info as you can (incl car year) and then asking it for a solution. You will be amazed at what it can do. It does come up with spurious answers sometimes, so always double check the sources it uses.
| All times are GMT |
