Home > In Car Electronics > Cruise control - problem
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. The cruise control on/off switch doesn't always activate when pressed "on". If I turn the ignition off......then on it will usually work, but that isn't always convenient. Any thoughts as to what I can do to possible have the control working as it should? Andrew Kennedy
Post #650339 Mon Oct 27 2025 1:11pm
check if any fault codes stored
Post #650344 Mon Oct 27 2025 3:55pm
andrew kennedy
Unfortunately I don't have the device for checking - I will get the garage to have a look next time I visit. Anything I might be able to do in the hope it might clear the problem. Andrew Kennedy
Post #650347 Mon Oct 27 2025 5:25pm
You could check the horn works or radio controls work on full left lock and full right etc.
Post #650348 Mon Oct 27 2025 5:43pm
