![]() | Home > My Range Rover Sport > Range Rover Sport HSE Lux |
| Hoggers Member Since: 21 Oct 2019 Location: Hampshire Posts: 15
I noticed my dials were sticky so took them off and put them in hot soapy water and the gunk just peeled off
| SuperC Member Since: 24 Feb 2016 Location: Midhurst, West Sussex Posts: 90
Good looking car! Cheers,
Thanks! I love the colour combo … black outside, black leather, black headlining … with sunroof. |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5153
I used these covers when the rubber on the rorary control knobs went all sticky and gungey on mine.
Nice. I don’t mine has ever been cleaned in 13 yrs so has clearly picked up a lot of grime in that time! Surprised how easy the stuff came off once heated up |
Single stage polish...
Nice job on the polish! Triple black is very nice. Don’t know if my rotaries are sticky or not. Its been set to 22 for 10 years |
Decided to refresh the discs and pads all round - they weight a ton!
| T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 106
My control knobs were too far gone and no amount of cleaning or solvent would touch them.
Have you had your steering wheel refurbed? |
Hi, No it was a replacement exchange steering wheel from PowefulUK a few years back.
Nice.
They were a 3 piece accessory kit L/R did for the 05-09 sport which I had for my 09 plate but never fitted, they will fit the 10-13 cars, but had to modify the throttle pedal as it is slightly wider than earlier cars, just had to narrow it down a couple of mm done in situ with a dremel though. If I remember right also had to cut the notch in the pedal cover rubber slightly wider where it fits over the pedal.
