Home > General (L494) > Stretching Rubber Noise when going into extended mode
Karlp606
Hey guys,
Got a strange cabin only noise of almost a stretching rubber noise when going into extended mode, I've listened on the outside the car with my wife inside highering/lowering the suspension and there's no noise, its only inside the cabin around the pedal area.
Ive had the lower arms & suspension arms replaced in the last 9 months and also had them checked out at my garage at my last oil service and they said they were a little dry so added some grease etc. Im still getting a lot of squeaking especially when it warmer dry weather - Is there anything I need to look at or another suspension part that needs replacing.
PS We had the front roll bar bushes replaced about 6 months ago too.
Post #650142 Fri Oct 10 2025 11:27am
41jules1967
Probably is just the bushes etc stretching into the extended position as it's rarely set that high.
In dry weather, rubber bushes dry out. You can temporarily quieten them down with various sprays but they'll usually return. Then when the wet weather returns, and the air is damper, it all quietens down.
I really wouldn't worry about it. 2021 L494 D300MHEV Autobiography
2019 Discovery Sport D180 HSE
Post #650143 Fri Oct 10 2025 12:51pm
Karlp606
Hi thanks for the reply.
I dowsed everything again underneath but still I’m getting a lot of hard creaking rubber noises, it only seems to be at slow speeds , like when setting off from stationary you will hear it but again only in the cabin no noise on the outside - when the car is 30mph going over bumps/around corners no noise?
I’m thinking could it be the anti roll bar bushes been possibly too tight in the in the sub frame and not been able to move freely? But would these move when stationary and going into extended mode??
Or if the garage have over torqued the suspension arms and causing noise from the ball joint?
Post #650243 Sat Oct 18 2025 10:05am
