![]() | Home > Wheels & Tyres > MT tyres to North Cape |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
You are pretty limited for MT tyres on a 19 inch wheel, unfortunately. The standard size is 255/50/r19 but you can fit 255/55/r19 quite happily. In the UK, at least, you'd be pretty much limited to the General Grabber X3 and then some from the likes of Comforser (a Chinese maker) and the Davanti Terratoura M/T although I've no experience with any of them. 2012 SDV6 - it's missing a couple of cylinders
BBernt Member Since: 08 Oct 2025 Location: Tromsoe Posts: 4 ![]() ![]() |
Thank You for answer. Is there any point of lifting the car with Johnson (?) rods?
Generally speaking, if you raise the ride height, the ride becomes a bit harder. Not sure why that should be but it's my experience anyway. Never used Johnson rods but no reason not to use them, just remember that you reduce the amount of spare travel in the suspension should you find yourself sat on a bit of high ground. As a cheap method of raising the standard ride height, rods work fine.
We where in Finnmark last month, on a sami trail, and a V8 RR P38 came along. He had MT that war a little bigger than standard, and could keep up a bette pace than I could. He had also mounted coil springs and impressed me with on the stoney trail.
Wow, that's a huge price difference and going for the Comforser makes total sense for your use. 2012 SDV6 - it's missing a couple of cylinders
