![]() | Home > Technical > Gearbox update |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 153 ![]() ![]() |
My 3.0L V6 has just covered 140,000kms and I got the mechatronic seals changed out yesterday. Obviously, as it drove out of the workshop, the shift points were all over the place. Furthermore, there was an obvious lag shifting from 3rd to 4th.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
generally I wouldn't update it. However, there is a fix for something call the californian shunt or stop.
RallyeSport Member Since: 20 Jun 2024 Location: Gloucester Posts: 110 ![]() ![]() ![]() |
For info.....
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
Not sure everyone is against software updates, personally don't really see the logic in updating something unless someone has a issue of some sort which it may rectify, but on L/R previous record of updates it sometimes make the situation worse. |
I'd be cautious about software updates. There is always that outside chance that you could brick your vehicle if something does go wrong. Also, there's the chance the update solves one problem, introduces another. So I would not update unless absolutely necessary. |
Well, thanks for the replies.
