![]() | Home > Faults & Fixes > Beep over speed bumps & rev's when cold P400 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
This is probably way off the mark, but do you have a dashcam fitted? as on my Thinkware camera it has a impact/motion setting if it is set too sensitve it beeps over speed bumps etc. so have it set as off. Probably of no relevance to your issue but only a suggestion.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 784 ![]() ![]() ![]() |
My P200 Evoque (same 2ltr 4 pot ingenium engine?) and a P250 I breifly had does the same. I guess it's a protocol to ensure oil pressure on start up. I do tend to let the revs drop before engaging gear.
