Home > Faults & Fixes > Coolant leak - pressurised system can see leak near engine
jig
2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Hi guys,
Need your help and advice on what to check for having a coolant leak, hoses seem ok but there is water near the engine, where should I be checking? What is the likely culprit? coolant tested with a pressurised kit.
Thanks in advance
Range rover sport diesel 2011 L320
Post #650092 Sun Oct 05 2025 12:32pm
there is a plastic bridge between the heads, and connected to hoses on the front.
These are known to crack. (make from plastic) So I would get one of them ordered.
Take it apart to investigate, and if its not that causing the leak, well it needs changing anyway
metal aftermarket:
https://www.ebay.co.uk/itm/177382644287?_s...BMxJvwwrZm
https://www.ebay.co.uk/itm/276222863184?_s...R9bW-sK2Zg
you may want to order elsewhere, but this gives you some pics to look at
Post #650093 Sun Oct 05 2025 12:44pm
jig
thanks Andy good shout. will order. how hard is it to get to the part? any other likely causes? thanks again
Post #650094 Sun Oct 05 2025 2:53pm
Not difficult.
There is a fuel / coolant heat exchanger further back / behind it
Post #650095 Sun Oct 05 2025 5:40pm
