Home > Maintenance & Modifications > Andy - Turbo problem
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Andy - seeing our cars are similar models - 2006 Sport, I am hoping you might be able to advice me on a couple of things,
The car had lost it power which is/was due to the turbo not kicking in. The local Land Rover guy will try to fix it next month with no guarantee it won't reoccur – if it does go on the blink again, is there some way I could try to free it up? I can see online there are products on the market, but I can't find a website that shows how to do it on my model?!?
Also, am I right in thinking there is not up to date disc available for the cars built in GPS Andrew Kennedy
Post #650055 Fri Oct 03 2025 10:33am
I and other landrover owners have used this product/manufacture with success. If you get the problem again, just add it to the fuel tank, (e.g when 3/4 full from memory) and drive normally.
Before refilling, you could test the cars performance to ensure its worked.
Wynns turbo or vvt cleaner. Purple bottle.
As shown below. Worth getting some and you can keep in the car
https://www.ebay.co.uk/itm/175868648288?_s...R7Sq-5q1Zg
Apparently you can getting coppied map updated discs. The voice button will no longer work.
Sorry I don't know where from. I have fitted the facelift Nav. Mods: FaceLift/D4 Sat Nav Display and reverse camera. BT. Remote FBH. Parking light switch position. Rear reading light activated by doors.
Post #650059 Fri Oct 03 2025 11:53am
andrew kennedy
Thanks Andy! Very helpful. Andrew Kennedy
Post #650062 Fri Oct 03 2025 1:33pm
