Home > Technical > Retrofit TV
RallyeSport
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
Retrofit TV
Hello,
For what its worth, probably a dumb choice.
Id like to think I could retrofit a TV module to my Autobiography Sport 2010.
I have factory fit rear entertainment as standard and wondered if I could loop into this system, seeing as though I have the fakra and fibre optic for the rear screens, is it possible to add TV to the system.
I have the 3x antenna modules which would live in the drivers side rear window, as I bought a job lot when I was chasing the lack of DAB reception a few months ago.
I understand Id need the TV module, that sits further forward of the DAB module on the left side of the boot area.
Am I being dumb thinking I can add the TV in?
or would I need to run a separate fakra and fibre optic to the headunit? like in the guide that was created a few years back which someone was kind enough to create on here.
If its too much hassle, its not too much of a problem, as I understand the reception is sketchy anyway so I'm lead to believe?
Also, whilst on the subject of retrofitting....
I have programmed timed climate to my display screen and it turns on the FBH every time. I see a kit on ebay for £159 which is sold as a kit for the L322, the guy asked me what colour plug I had in the offside boot area space, Id responded it was black, but thats the last I heard from him.
Again, is there a kit I can buy or do I need to buy the parts individually, I understand its a Telestart T91.
Cheers in advance
Dean
Any thoughts?
Dean
Post #645308 Mon Nov 18 2024 9:35pm
Might help, but unless TV programmes have improved since I lived in the U.K I wouldn't bother, probably more trouble that it's worth, unless you keep the engine running it will shut down after few minutes.
https://drive.google.com/file/d/15mLqoCdYr...drive_link
Post #645311 Mon Nov 18 2024 9:52pm
RallyeSport
Hi Col,
Yes I'd seen the 'how to' guide.
From what I can see if I already have Rear Entertainment I need a lead to add into the system.
I just wondered if anyone in the same situation as myself had successfully added it?
I'm not sure however like you say the worthiness of it, due to crap reception.
Id be more interested in adding DAB+ which I understand others have done, which would be more beneficial to myself.
Dean
Post #645317 Mon Nov 18 2024 10:50pm
RallyeSport
Reading through this ‘how to’ again, if I have RSE as I have, do I still need to run a cable to centre console? I’d of hoped I could have added the relevant to tuner boxes in the rear windows and the module?
I appreciate the tuning and reception was to be desired, I’d probably not bother.
My mrs has TV in her Mercedes ML and the channels are endless.
Cheers in advnce
Dean
Post #649897 Sat Sep 20 2025 9:03pm
With you only being able to watch while stationary
And the fact it shuts down after 5 mins with the engine off it’s pointless.
Yea I think you need to run a cable to the front. Not fakra in 2010 though.
Regarding FBH. Look on disco 4 forum. That’s the setup you need
Post #649898 Sun Sep 21 2025 5:02am
RallyeSport
I’ve programmed in FBH and have it on the remote now, nice little mod.
As for TV it would just be a gimmick thing, I’ve an autobiography on a 2010, so understand it should be reasonably straight forward I’d hoped, already having the rear screens.
Handy though if your a caravanner like I am and can watch TV while the mrs is in tescos.
Cheers Dean
Post #649900 Sun Sep 21 2025 2:40pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
As your RRS has the rear screen entertainment system you can already watch DVDs when the better half is at Tescos. Who needs TV.
Post #649902 Sun Sep 21 2025 4:37pm
RallyeSport
Good point on the DVD's.
But I've always enjoyed retrofitting parts to cars.
Anyone ever done it with Rear Seat Entertainment?
Reading the link to disco website, it talks of the RSE if in place, its not as involved, but wondered if I still need to send a cable to the screen? I'd of hoped the MOST system would of allowed me to add into the chain.
Dean
Post #649926 Tue Sep 23 2025 8:14pm
TheWojtek
OldJaguar on AULR does this on a regular basis.
Mind you, the hardware of the only TV tuner you can attach to this car is a bit dated and as broadcasts move to Full HD or even higher resolutions, it will soon become obsolete.
The factory RSE screens are far from any contemporary resolution standards as well.
What I would do is I would use the existing wiring (with some additional wires needed to be ran anyway) to upgrade the existing system to a "media center" that may include a TV tuner as well. While it will definitely be aa custom setup that won't be managed with the front screen controls, it may be something just as exciting to add to the car. Swap the screen for something HD and maybe larger, run HDMI to a splitter, use a Raspberry Pi as an in-car entertainment center with Plex, streaming, live TV... Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #649927 Tue Sep 23 2025 11:10pm
Meiang
Nothing better than watching an episode of The Professionals or Columbo while the wife does her supermarket stuff. Watching Bodie and Doyle doing their stuff passes the time very quickly.
You just have to remember to allow enough battery power to start the car.
Post #649929 Wed Sep 24 2025 8:17am
