Home > Technical > RRS 2010 FAULT CODES HELP WITH VACUUM LINES PLEASE P22D3 P22
Ln59ej
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hello everyone new owner here
2010 3.0 tdv6
Getting restricted performance above 3000rpm
Fault codes come up as above a i know there for the drivers side turbo wastegate
So far I have
Checked wastegate manually and it moves fine on the turbo and shows it moving fine from 0 to 100 percent on Diagnostics
What I have found is all my vacuum is going into the airbox pipe teed off from main vacuum goes left into air box then right to all the solenoid valves I cannot understand this as it will never have a vacuum?
I'm waiting to know ideally a picture showing the vacuum pipes to see if I'm missing something or it's been piped wrong
Any help would be a appreciated thank you
Post #649827 Tue Sep 16 2025 12:53pm
