Home > Technical > Reason for Crankshaft breakages and how to avoid.
Page 2 of 3 <123>
Pistnbroke
Writing a post like this is like writing an exam question. Many candidates dont read the question fully or understand.
I re viewed the LR time video.
the crank failure on Fabián's car was caused by...
Original owner changing the oil annually but exceeded the change interval by mileage.
ie poor oil quality
Excess cranking for starting (5 sec or more) caused by a failing fuel pump.
ie lack of lubrication to crankshaft while cranking.
So
check your oil pressure and use a thicker oil remember that no 5w30 oil meeting the original LR spec is made in 2024. and cross your fingers. Always listen to old people or when they die you will live on in ignorance.
Post #639500 Fri Feb 09 2024 10:33am
erickwan
Malaysia
Lots of other engines suffer a lot more abuse with a lot less damage.
Post #639502 Fri Feb 09 2024 11:21am
And the vast majority of LR V6 diesels do big miles with only normal servicing and using 5W-30 oil at 16k mile intervals (or whatever the book requires for that model). 2012 SDV6 - it's missing a couple of cylinders
Post #639503 Fri Feb 09 2024 11:32am
Perhaps someone who had to crank the thing for several seconds each time should have had that looked at. A fuel pump is cheaper than an engine. 2012 SDV6 - it's missing a couple of cylinders
Post #639504 Fri Feb 09 2024 11:35am
Karlp606
Ive said it before on a few other forums ;
1. Poor Servicing - not servicing the car correctly, eg leaving it to long in between services
2. Starting the engine and just driving off, you need to treat these cars/engines as they are a 1950s Jaguar, engine on and leave for about 10-20 seconds before engaging the gear box, let the oil circulate and if its even colder leave it a good couple of minutes to allow the oil to warm through the engine.
3. Heavy driving , over revving the engine putting unnecessary wear on the engine and crankshaft as the crank is already weak dont constantly drive the car at 4000+rpm , its not a rear wheel drive ford focus ST.
If you bear in mind the engine and crank are made of weak materials why force it to break.
Post #639516 Fri Feb 09 2024 2:39pm
erickwan
Malaysia
Why take it off-road?
Post #639519 Fri Feb 09 2024 3:19pm
The engine makes peak torque at low revs. At high revs, the torque is c.100lbft less than at 1500-2000. Lugging at low revs puts more strain on a torque sensitive component. Yes, driving around on the rev limiter won't do it any favours, but making occasional use of the full rev range available isn't the cause of these [relatively rare] failures.
And the vast majority of the engines aren't made of "weak materials" which is why the vast majority don't snap their cranks. 2012 SDV6 - it's missing a couple of cylinders
Post #639520 Fri Feb 09 2024 4:17pm
NoExpert
Quote:
So
I’m having a hard time with that one. Ravenol makes FLJ 5w30 C1, Castrol makes Edge Professional 5w30 C1, LiquiMoly makes 5w30 C1, Quantum 5w30 C1, Shell Helix Ultra 5w30 C1 and many others.
The ACEA C1 class has been discontinued as an oil specification for new engines. It has not been discontinued by oil manufactures that I’m aware of.
I absolutely agree with giving the engine some running time before driving off as well as after a long run or a spirited drive. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #639530 Sat Feb 10 2024 5:34am
erickwan
Malaysia
[quote="RRSTDV8"]
If ever there was poor assembly work, "weak" materials or simply poor design, then the engine was sold on a "not fit for purpose" condition. In the USA, a class action lawsuit would ensue. Some lawyer would want to take that to the Courts on a no-win, no-fee basis.
Post #639531 Sat Feb 10 2024 6:07am
Pistnbroke
Quoting from LR time " Oil " video and cannot find an oil here that is over the specified >3.5 sheer required.
Been studying the C6 Citroen ....a few crank failures but a lot of comments on bad oil pumps ???
and talk of running it for long periods over 4000 rpm causing the con rods to stretch distorting the bearing housing...who knows. Citroen will only supply short blocks .no pistons/rods or shells.
They specify oils 0w30 5w30 10w40 and 15w40 but I saw no climate ranges for each oil.
One guy at a LR dealership said all the broken cranks that had come in had low oil ..
Personally I dont see mine at over 3000 rpm Always listen to old people or when they die you will live on in ignorance.
Post #639532 Sat Feb 10 2024 9:24am
NoExpert
Citroen C6:
Engine Specification
Power 177 kW
Horsepower 241 hp (238 bhp)
Rev. at Max Power 3,800 rpm
Torque 450 Nm
Torque 332 lb-ft
Rev. at Max Torque 1,600 rpm
Engine Fluids
Engine Oil, Volume 6.25 l
Engine Configuration
Displacement 2,992 cc / 3.0 l
Cylinders 6 Cyl. / 4 V per Cyl.
Bore 84 mm
Stroke 90 mm
Compression Ratio 16:1
Engine Configuration V-Engine
Turbocharger Twin-turbo
Synchronization Timing Belt
RRS L320 2010/2011:
Power 180 kW
Horsepower 245 hp (241 bhp)
Rev. at Max Power 4,000 rpm
Torque 600 Nm
Torque 443 lb-ft
Rev. at Max Torque 2,000 rpm
Engine Fluids
Engine Oil, Volume 5.9 l
Displacement 2,993 cc / 3.0 l
Bore 84 mm
Stroke 90 mm
Turbocharger Yes
Quick takeaway; RRS uses a sequential turbo setup while Citroen is a twin turbo setup (both run at the same time). RRS makes quite a bit more torque and a little more HP. RRS has slightly lower oil capacity. RRS has slightly higher max HP and torque RPM points. RRS weighs around 2500kg, Citroen C6 weighs about 1875kg.
The 5w30 ACEA C1 oil spec is essentially a Ford oil spec. ACEA decided to move away from manufacturer specific specs and go to a “these are the specs, manufactures choose which works best for their engine” system. I believe this is why JLR left the ACEA C2 backdoor, they knew C1 may not be stocked at a lot of places (I can get C2 off the shelf at a few auto shops in Poland, I have to order C1). 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #639542 Sat Feb 10 2024 1:50pm
And in the RRS, that same engine also had a 190kW (254hp) version. And the L494 3.0V6 diesel increased that to c.300hp/516lbft. 2012 SDV6 - it's missing a couple of cylinders
Post #639543 Sat Feb 10 2024 2:17pm
NoExpert
Exactly, which is why I noted the years for the specs listed. Also worth noting is the later mentioned by RRSTDV8 also run the 8HP 8 speed auto transmission. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #639545 Sat Feb 10 2024 2:28pm
As noted the earilier RRS 2.7 is closer in age and design to the C6, and Jaguar and the Pug.
Apart from the turbo setup. The cars have more BHP than the LR.
Interesting you found some Citroen failures. People say jaguar failures are rare.
Personally I don't blame the DPF as I believe cars without DPF also fail.
I think LR Times explanation of the short block (required for the French FWD cars) is the design problem
As for long cranking times. I think this is only at ~100 RPM? I worry more about the time it takes for the Oil light to go out. In bad cases this can be 5 seconds? and at 800?RPM a bigger worry
Post #639546 Sat Feb 10 2024 3:16pm
On a related note, here is some interesting information on the SDV6 Gen 1 vs Gen 2 engine: https://www.disco4.com/forum/306dt-engine-...11280.html --
Post #649765 Fri Sep 12 2025 12:43pm
Page 2 of 3 <123>
