Home > General > Battery Monitoring
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Battery Monitoring
I have just bought a Veratron (VDO) battery monitiring kit (VL Flex 52 - IBM Kit ). It is designed for boats but can be used for other purposes.
The 52mm gauge shows battery voltage /current draw /battery SOC and battery temperature. It can show either a single display or a dual display at the push of a switch. It is programmable by your phone.
It's perfect for the Range Rover or any modern vehicle that has a high battery demand.
It just requires the battery hardware to be attached to the negative terminal of the battery. My car does not have a BMS system so I do not know how it will interfere with cars fitted with a BMS system.
It is nice to see battery voltage and the current draw simultaneously. Here is the web link.
https://veratron.com/products/vl-flex-52-ibm-kit-12v-black
Post #649436 Fri Aug 15 2025 6:28am
