![]() | Home > General (L494) > Auto box logarithms |
| TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 752
The transmission reacts to your intentions as you express them via your right foot. It interprets both the depth of the pedal movement and the speed of the movement. The shift logic is immensely complicated and to make things more complicated, it is a self-learning mechanism so each car behaves differently.
| 41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 150
As TheWojtec really - it's a learning algorithm that has a base map and then adjusts to the driver inputs over the last 30 miles or so. Hence if you drive agressively, it will hold gears longer and be more eager to kick down. If you drive like Miss Daisy, it will change up earlier and be less eager to come back down.
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
The centre diff on the single speed transfer box is a planetary type torque sensing differential. Normally, torque is split 40% f/ 60% r but can be diverted up to 65f/35r or 20f/80r. It works by using internal friction to direct the torque to the front or rear shaft.
