![]() | Home > Wheels & Tyres > 275 50 20 ?? |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 427 ![]() ![]() ![]() |
"I did however re-calibrate the suspension to lower the ride height slightly to compensate for the slight increase in height on fitting the 45 profile tyre and 21" rims".
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
That was with the 21" rims, never changed anything with the 20" 45 profile and it still had no effect on the handling, just improved the ride comfort slightly and made the speedo a little more exact. I did play about with different wheel/tyre size settings in the CCF and it made no noticeable difference to anything so left it as it was when it left the factory. The car I fitted the 21" rims to also has the CVD system fitted, but I wouldn't know if that would make any difference to the handling with the large wheel/tyre combination.
