teldec
The iCarsoft LR V2.0 comes packaged with a wide range of useful features for technicians, including:
General Diagnostics: Read and erase fault codes, and detect and translate the most common codes and warnings on the vehicle display. This includes the airbags, transmission, and engine, among others. Access to a full DTC library, as well as the ability to clear and read data in real time.
Multi-Language Support: English, French, German, Spanish, and Dutch
Compatible with a wide range of OBDII/EOBD testing modes (J1850 PWM, CAN, J1850 VPW, KWP2000, ISO9141)
I/M Readiness indicates whether or not the various emissions-related systems on the vehicle are operating properly and are ready for Inspection and Maintenance testing.
Freeze Frame - When an emission-related fault occurs, certain vehicle conditions are recorded by the onboard computer. This information is referred to as freeze frame data. Freeze Data is a snapshot of the operating conditions at the time of an emission-related fault.
O2 Sensor Test -- This option allows retrieval and viewing of O2 sensor test results for most recently performed tests from the vehicle's onboard computer.
On-Board Monitoring -- This function can be utilised to read the results of on-board diagnostic monitoring tests for specific components/systems.
Retrieve generic (P0, P2, P3, and U0), manufacturer specific (P1, P3, and U1) codes and pending codes
Improved live data reading, complete with colourization, live updates, and speedy refreshes
Printing: After retrieving important data via customised testing or scanning, you can then print it out for your records.
Accessible Interface: Highly readable screen and large silicone keys
