![]() | Home > In Car Electronics > Changing headlight direction for Europe |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 750 ![]() ![]() ![]() |
The dash menu only sets the high beam assist for LH and RH driving by appointing the system to monitor the left front or right front side of the car. It does not change the asymmetrical low beam pattern to LH or RH, this is done by the lever in the headlight itself. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
The headlamps on the last of the L320's didn't have the lever to adjust either due to the beam pattern, I personally found the high beam assist a waste of time as well.
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 235 ![]() ![]() ![]() |
From the owners manual:-
