![]() | Home > Technical > L320 3.6 TDV8 mapping |
| Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 101
I recently had the EGR's blanked with a software update and BAS engine remap on my 2008 TDV8. I also had the gearbox flushed.
| RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 113
Thanks for the reply.....
Mines done 81,000 miles, which for an 08 is pretty low.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
I had my 5.0L s/c remapped, although it has the 6HP28 transmission which is rated slightly higher at 650nm, it throws out 750nm of torque well 749nm to be exact and that reading was actually taken on a dyno, not some "a pie in the sky" figure, that was some 8/9 years ago and have never had any issues with the transmission yet.
| TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 752
The 6HP TCM (which can be mapped, but that's a different story) has built-in torque limiters for each gear and will send a torque reduction request to the engine ECU if the input torque is sustainedly above the software limit.
| All times are GMT |
