Home > Technical > Crank Position Sensor
dannyric
Australia 2008 Range Rover Sport TDV8 HSE Santorini Black
So,
it seems like I have a faulty crank position sensor (CPS)
TDV8 3.6 lion. l320. I've sent an inspection camera in and I can see one of the sensor cables has split.
I can't find any good guides on replacing this thing. It appears to be hidden behind a bracket, attaching one of the turbos.
Service manual seems to simply say remove the heat shield and undo the bolt. Not entirely helpful.
Is it even possible to replace this without lifting the body? Has anyone done this job on another Range Rover Sport 3.6?
Post #648860 Wed Jul 16 2025 1:41am
Crank position or cam position?
Crank position sensor is a transmission out job as you have to remove the flexplate.
Cam position is digging down through various gubbins to get to it. 2012 SDV6 - it's missing a couple of cylinders
Post #648864 Wed Jul 16 2025 9:46am
Disco_Mikey
Sensor can be done in place, albeit a fiddly Censored of a job
Trigger wheel is box out...
https://www.rrsport.co.uk/forum/post620648.html
Post #648866 Wed Jul 16 2025 10:01am
dannyric
Definitely crack position sensor.
I’ve seen that other post, think I’m getting stuck with the ‘turbo mounting plate’ ?
Have a stuck bolt in there that won’t budge, half behind another plate, i think parts of the turbo connect to?
The chunky looking mount has a ford logo on it and three 10mm bolts that I can see?
Directly behind the plate I can see the rubber grommet hiding the sensor.
Just stuck and can’t seem to get any other bolts off.
Post #648876 Wed Jul 16 2025 4:29pm
maybe some video's or pics in this thread on the v6 which maybe of help
https://www.disco3.co.uk/forum/topic206795-60.html
Post #648877 Wed Jul 16 2025 4:56pm
dannyric
Not much more helpful, still not the same engine. Same sensor, but access seems easier.
I’ve seen that youtube video and the location of the sensor seems to be different for that engine.
“Ricky and Paul’s Autoshop” has comments turned off on their youtube, probably got sick of the comments section correcting their misinformation.
Post #648879 Wed Jul 16 2025 5:24pm
dannyric
Is there enough wiggle room to split the transmission with the car on jack-stands or is this another body off job?
Seems once the flexplate is removed the sensor is just under..
Post #648880 Wed Jul 16 2025 5:36pm
