V8Alpinist
Sudden System Shutdowns & Electrical Glitches 2008 RRS T | |
Hi everyone,
I’m driving a 2008 Range Rover Sport TDV8 (L320) and have been struggling with a strange electrical issue for a few weeks now. I’m hoping someone here has experienced something similar or can help me narrow it down.
Note: If there are any existing threads on this topic, I’d be very grateful for a link. I’ve tried searching the forum, but since English is not my first language, I found it difficult to verify whether the entries match my situation.
Timeline of Symptoms:
1. First occurrence (about 3 weeks ago):
• Ignition on → only dashes in the instrument cluster, no temperature or time shown
• Message displayed: “System control in progress”
• Turning the key → nothing happens, engine won’t start
• Suspension fault message: “Suspension fault. Vehicle may lean when cornering” (Aufhängungsfehl.
Fahrzeugneig in Kurven)
• Battery measured at 11.9 V
• Charged overnight to 12.9 V → same issue
• Replaced the battery → vehicle started normally, all errors gone (for about 10 days)
2. Intermittent failures:
• After 5–10 minutes of driving:
• Beep + suspension warning Suspension fault. Vehicle may lean when cornering” (Aufhängungsfehl.
• Complete failure of dash, lights, radio, nav, windows
• Engine keeps running
• After 2–3 minutes: system reboots, most functions return
• Yellow suspension warning light stays on (aufhängungswarnleuchte)
• Next ignition cycle → everything back to normal
• This behavior repeats randomly
• When the system fails, the radio displays: “Vehicle Fault – System Shutting Down”
• Also: hazard lights activate automatically without touching the switch (possible safety function?)
Technical checks:
• New battery: 12.98 V resting voltage
• Alternator charging: 13.75 V at idle
• Voltage drop between battery and engine block: 0.021 V
• Front 12V socket shows burn marks inside, but fuse is intact
• Audible clicking under driver’s seat after failure
Known issues & work done:
• Driver’s door latch faulty (replacement ordered)
• Front sway bar bushes worn
• Slight leak on rear stabilizer, hydraulic fluid was at minimum
• 12V socket confirmed damaged – removed (USB-C version ordered)
Work already done:
• Replaced battery
• Checked grounding points in engine bay
• Removed CJB (Central Junction Box), found and re-soldered several cold solder joints
→ Door latch worked immediately after
• Cleaned ground near A-pillar in passenger footwell
• Reinstalled CJB, cleared all error codes → system worked fine for 3 days
• On day 4: issue returned exactly as before
Questions to the community:
• Has anyone ever experienced such a chain reaction of electrical failures?
• Could a faulty 12V socket or internal short really crash the CAN bus or body systems?
• Are there additional ground points or harness connectors in the cabin or trunk I should inspect?
Any help or advice would be very much appreciated.
This car is a joy to drive… when it works. 😅
Best regards,
Eki
Tue Jun 03 2025 8:59pm |
V8Alpinist
Hi all,
My never-ending RRS story continues – and I’m hoping for some insights from the community. Maybe someone has seen similar symptoms.
🔧 What’s been done so far:
Checked all ground points in the vehicle and at the battery
Removed and re-soldered the CJB (Central Junction Box) due to cold solder joints
Removed the 12V socket (had visible burn marks)
📉 Current issue:
I noticed the air suspension compressor runs excessively long, even after the target height is reached.
→ It gets very hot
→ The car displays: “Suspension raising slowly”
I performed a leak test with soapy water on all connections – no leaks found.
🛠️ Workshop visit & professional diagnostics:
I had the car checked at a Range Rover specialist using professional diagnostic tools.
Result: multiple communication faults between ECUs
Their suspicion:
→ Possibly a faulty control module behind the battery (potential water ingress?)
Back home, I removed the battery and inspected all connectors – no signs of moisture, no corrosion, everything dry.
🧪 Fault codes from iCarsoft LR V3.0:
RLM: U0416-86
ATCM: U0416-94
VDM: U0128-87, C1A00-88
Side note: My iCarsoft V3.0 often causes HDC faults / “Special Programs Off” as soon as I initiate a diagnostic session, which makes troubleshooting even harder.
🚘 Interestingly:
I drove over 100 km today – city, highway, country roads – and no errors showed up during the whole trip. The car performed perfectly.
❓ Questions:
Has anyone experienced similar behaviour?
Is anyone using the iCarsoft LR V3.0 with the L320 and noticing communication problems, especially with VDM or the ACE module?
Thanks in advance for any ideas or suggestions!
Cheers,
V8Alpinist RR Sport TDV8 & Evoque Si4 | I can’t afford more, but at least I break down in style
Thu Jun 05 2025 9:46pm |
V8Alpinist
Hi all,
📉 Current issue:
→ It gets very hot
Their suspicion:
RLM: U0416-86
ATCM: U0416-94
🚘 Interestingly:
❓ Questions:
Cheers,
V8Alpinist
Hi all,
📉 Current issue:
→ It gets very hot
Their suspicion:
RLM: U0416-86
ATCM: U0416-94
🚘 Interestingly:
❓ Questions:
Cheers,
Thu Jun 05 2025 9:47pm |
V8Alpinist
Hi everyone,
I’m honestly pretty frustrated at this point and really don’t know what else to try.
Before I bite the bullet and take the vehicle to a Range Rover dealership (and believe me – here in Switzerland that means serious money), I wanted to reach out to the community one more time in hopes of tapping into your collective wisdom.
The issue is unfortunately still unresolved.
I’ve followed a number of tips from fellow L320 owners and self-proclaimed experts – many thanks to everyone who contributed – and I’ve carried out all of the following steps as thoroughly as possible:
✅ Replaced the battery
✅ Checked and cleaned all ground connections in the engine bay and inside the cabin
✅ Removed and re-soldered the BJB (engine bay fuse box)
✅ Checked the ECUs behind the battery and on the driver's side for moisture – all bone dry
✅ Replaced the brake light switch
✅ Replaced the alternator – The new one delivers a solid 120A; voltage at idle is around 13.8V. The old one maxed out at 65A under load.
This morning: Car started without issue. I drove it, turned it off and on several times – everything worked fine.
Four hours later: Tried to move the car – bam, same fault again. No crank, no start.
I’m starting to suspect a fault in the instrument cluster (dashboard) or maybe an ECU that fails to wake up from sleep?
Before I tear apart the dash or hand over 2,000 CHF to a main dealer:
Does anyone have a hidden trick, a common gremlin, or a fresh idea that I might have missed?
Many thanks in advance – I truly appreciate every serious suggestion.
Greetings from Switzerland, V8alpinist RR Sport TDV8 & Evoque Si4 | I can’t afford more, but at least I break down in style
Sun Jun 29 2025 10:15pm |
