Home > Maintenance & Modifications > Oil leak drivers side
Tiprat
Good morning everyone, so my responsible adult has bought a RRS 2013 3lt tdv6 114k. So this weekend was service time, got all the kit from Maltings and everything went as easily as expected. Whilst doing the fuel filter, I obviously had to remove the sump guards. This is when I noticed an oil leak. The metal sump had oil residue on it and so did the pipe work above, the leak is obviously from the engine dripping down from above as the gearbox sump is dry and also the transfer box ect. The area the oil is dropping on to is below the driver's side windscreen, now I'm new to the tdv6, having previously worked on the 3.6tdv8. so my knowledge is limited. Has anyone any suggestions as to where to look for the leak, I know everyone will say clean it up and look again but I couldn't clean it on the drive as all the oil would end up on the drive...also if people do know what might be leaking could you also let me know if it could be done on the drive or if I need to send it in to say a specialist like Landranger in Atherton.
Regards
Tiprat.
Post #648491 Mon Jun 23 2025 9:22am
