![]() | Home > Technical > Range Rover sport 2005 radio low power mode |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5116 ![]() ![]() ![]() |
these cars do not have a radio code, so feel free to try what you wish.
sophie.weatherby@me.com Member Since: 16 Jun 2025 Location: Manchester Posts: 5 ![]() ![]() ![]() |
So testing the power to the radio it is 11.7 volts when engine off and 14.7 volts when engine ticking over. Even getting 14.7 volts radio still in low power mode and no sound. Battery tested and fine, charging correctly. Surely it can’t be the alternator if radio getting plenty of voltage? |
so you can't hear any music at all ?
No, the volume button on radio and steering wheel both don’t work when in this mode. It will randomly kick back in which can be when driving or just unlocking the car even with radio off. |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1909 ![]() ![]() |
12 volts is low for a reading at the battery, that indicates only a 50% charge. Maybe worth getting it checked? 2023 P440e SE Dynamic on order -cancelled 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
Sorry maybe I should have been more precise. Engine off battery is reading 12.4 volts when engine running it is 13.88 volts. Radio voltage, when engine off is 11.7 volts when engine running is 14.7 volts. |
Just checked the fuses: f52 should be 5amp but someone has put a 15amp in and f53 sis and should be a 15amp but the blades look a little tarnished but not blown. After pulling them out and resetting radio it seems (fingers crossed) to have it working again. |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 352 ![]() ![]() ![]() |
Just replacing the fuses shouldn't make any difference regardless of their rating. Low power mode is a sure sign of short journeys, weak battery poor alternator .
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9114 ![]() ![]() ![]() |
Radio low power mode is a designed response to low voltage. The system will load shed various items in a particular order in order to ensure the battery has enough juice to start the engine.
