Home > Technical > Extra Cooling When Towing
The Range Rover
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Hi All.
I will be beginning to start towing a caravan again, and on my Towing Electrics installation manual, It states I might need to increase the cooling to my car?
Is this correct and what needs fitted?
And What might need upgrading in my Cars software ?
Thanks Colin
Post #648356 Fri Jun 13 2025 3:02pm
Disco_Mikey
Gearbox temps in this country are usually a non issue
The highest I'd ever seen in my own cars was 106 degrees, while climbing the M6 at Shap, with a trailer and RRS on the back, 3300kg in total
If your concerned, slow a little and drop a gear when climbing hills to keep temps a little lower
Post #648359 Fri Jun 13 2025 7:04pm
The Range Rover
Thanks For this, I have had 2 previous Range Rovers before and never had an issue, Just wanted to check .
Post #648363 Sat Jun 14 2025 9:20am
