![]() | Home > General (L494) > Normal Height / IEB Random Error |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 318 ![]() |
Just to further this , this is only happening on short journeys which makes me think its a battery issue?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9151 ![]() ![]() ![]() |
It would certainly be worth checking the state of the batteries. You say the stop-start battery is dead - have you checked it? If it is dead (and batteries don't last forever) then changing it would be the only solution. And then look after it.
Max100 Member Since: 28 Apr 2019 Location: Belfast Posts: 13 ![]() ![]() |
Hi, just wondering if there was a solution to this ? I have exactly the same problem. I have changed both batteries and still get the warning, probably once or twice every other day. |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
I've had this issue for a while now,, but it's completely random I did rebuild the compressor a couple of years ago or another reason and it was fine for a good while. Life got in the way so I lived with it,,, sometimes it's ok for days other time's it can happen a couple of times a day,,, it's always accompanied with " normal height only" and forward alert unavailable. I did manage to find that when this fault occurred there was still a supply (14v) to the compressor,, so in my mind it should still run ?. Problem is these are permanent magnet motors and are unserviceable,,, not as if you can drop some new brushes in. So I think the issue may well be the compressor but more so the motor itself rather than a mechanical part. I would love to get hold of another motor just to prove a point. 2010 RRS, TDV8
FIXED! new aftermarket compressor from eBay £150ish. No more problems and quiet as the original compressor . |
