Home > Maintenance & Modifications > Garage Near Dewsbury
Shaun W
Hi All,
I have had the Restricted Performance warning 3 times, last night I got loads of other warnings too, so I’d like to get it sorted.
Can anyone recommend and garages local to me in Dewsbury?
A friend of my wife works for Green Oval so that is an option.
Work will hopefully be done under the AA warranty.
Post #618124 Fri Oct 15 2021 10:06am
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Take it to Jas york, 30 mins down m62 will be best decision you can make, They even have courtesy loan cars if needed.
Post #618135 Fri Oct 15 2021 10:16pm
DrRob
JAS are excellent Visitor from fullfatrr.com
Post #618137 Sat Oct 16 2021 8:07am
Shaun W
So been looking on here for possible causes, as I have black smoke the common guess seems to be a crack pipe.
Opened the bonnet for a look
Looks to be a pretty big crack on the top, so hopefully an easy fix.
Post #618141 Sat Oct 16 2021 7:05pm
Shaun W
Just had it out to try the duct tape temporary fix, whilst waiting for silicon replacements to arrive, so took a better picture.
Post #618142 Sat Oct 16 2021 10:04pm
Shaun W
Thanks for your help everyone, hopefully I can fix this myself and save the trip to JAS for another time.
Post #618143 Sat Oct 16 2021 10:04pm
DrRob
Fit a silicone hose kit. Loads around for that engine Thumbs Up Visitor from fullfatrr.com
Post #618148 Sun Oct 17 2021 10:36am
Shaun W
That’s the plan.
I’ve ordered one from LR parts, top hoses look easy enough, will need to figure out how to do the others.
Post #618149 Sun Oct 17 2021 11:51am
Shaun W
Hoses arrived today, fitted the top two quickly, had to reuse the LR clips, so need to see if that has solved the problem.
Is there an idiots guide to replacing the other 4 that came in the set?
A quick look underneath (it’s been raining and I didn’t have a torch) I’ve found where one of the them goes but not sure about the other 3.
Post #618196 Tue Oct 19 2021 2:38pm
Shaun W
Autotel AP200 arrived this week so I have run a couple of scans.
First Scan on Friday showed 38 Faults
Todays 17 Faults
So I have erased them and see what comes back after a run tomorrow.
Oh boy, all hell broke lose this morning. Wouldn’t start lot’s of warning lights and eventually got it started and the Active Cornering Warning light came on and stayed on until I stopped and left it for a couple of hours.
Haven’t put the code reader back on it yet. Will leave it a couple of days before I see what is going on.
Post #618326 Sat Oct 23 2021 8:24pm
Westfield106
United Kingdom 2013 Range Rover Sport SDV6 HSE Stornoway Grey
Just had my arc pipes (front & rear) done & a service. Carried out by adventure services in Morley. Very helpful & informative. Very happy 👍
Mechanic Joe was very helpful.
Post #618550 Sat Oct 30 2021 7:25pm
jases4x4
Shaun, Did you find a guide or diagram where the other hoses go?
Post #648295 Sat Jun 07 2025 12:07pm
Shaun W
I never did. Probably still have them somewhere but I got rid of the Sport in Nov as the Turbos collapsed and it wasn’t cost effective to repair it. 2010 HSE TdV8 in Stornoway Grey.
Powerful Roof Rails and Spare Wheel protector
Post #648305 Sat Jun 07 2025 7:54pm
jases4x4
No worries mate, I have found where the bottom ones go onto inter cooler the small ones go near the turbo so do difficult to get to, I know how you feel with turbo costs, My steering rack might need replacing which is another big job, Just trying to replace lower uj but the bottom bolt is seized so its a nightmare job and ace pipes are in way to make it worse. What motor did you get after sport?
Post #648307 Sat Jun 07 2025 9:41pm
