83series3
| Anyone using ICarsoft V3.0 on their L320? | |
Hi all,
As I continue to try to get to the bottom of my never ending Dynamic Response issues, I purchased an ICarsoft V3.0 which arrived today…..
… however, it seems to be making the RRS very upset - as soon as I instruct it to diagnose, it throws up HDC Fault / Special Programs off errors on the car’s dashboard, and it won’t clear the offending codes. An ignition key cycle removes the lights from the dashboard, but they will come on again once I attempt to rerun diagnostics.
I’ve updated the firmware / software to latest, but that’s not resolved it (that will also have ruled out being some chinesium knockoff).
I also have access to an ICarsoft 930, which doesn’t cause any issues when running diagnostics, but only displays 4 digits with the OBD codes.
So, the question is, are there any others out there who are successfully using V3.0? Using the ICarsoft 930 as a baseline, I’m comfortable that the various codes that V3.0 reports (eg, U0001 CAN BUS) are caused by itself for some reason … thoughts? I have not gone back to the supplying company yet (ordered Friday at 1pm, delivered by Royal Mail Saturday at 10am - great service), as thought I’d check on here if it’s just me / a duff unit, or something else
Sat Dec 30 2023 8:41pm |
V8Alpinist
Hi, thanks for sharing this – very interesting.
I also have the iCarsoft V3.0 (Land Rover version) and I'm experiencing exactly the same issue:
As soon as I start a diagnostic scan (especially when accessing Dynamic Response / ACE), I get HDC Fault, "Special Programs Off", and occasionally suspension fault messages on the dash.
The tool won't clear these faults, even after trying several times.
Like you, I’ve already updated to the latest firmware, and the device is definitely authentic.
I'm now wondering: Did you ever figure out what caused it?
Is it a general issue with V3.0 units and the RRS L320, or just a software glitch?
Would be great to hear what the solution was (if any), before I contact support.
Thanks in advance!
– V8Alpinist RR Sport TDV8 & Evoque Si4 | I can’t afford more, but at least I break down in style
Tue Jun 03 2025 9:48pm |
