Home > General (L494) > Fault code P0336-29 Crankshaft position sensor A circuit...
kosio2001
Hi, I'm new here and hope someone can help me. I am the proud owner of a 2015 Land Rover Range Rover Sport with a 3.0 SDV6 215KW engine. I bought the car with a blocked crankshaft after the repair that I did, the engine runs great, but it keeps recording the same error, namely P0336-29. There are no lights on the dashboard and the car always starts fine. A little information about repairs and replacement parts on the engine. New Crankshaft, new crankshaft sensor, new crankshaft ring, new camshaft sensor, I tried new cables from the ecu to the crankshaft sensor as well with a new ecu but unfortunately nothing helped. The error continues to log and sometimes there is a very slight cutoff between 1000 and 1800 rpm as well as a slight vibration in the cabin at Idle. I am posting a few files with the Information which I receive from JLR SDD. Thanks in advance. Have a nice day.
Post #634207 Tue Jul 11 2023 8:25pm
chrisjsw
Was the crankshaft ring a genuine item or Britpart or similar aftermarket?
We recently had to re-remove an engine to fit a genuine part after a new aftermarket ring was found to be faulty 2015 Range Rover Sport L494 HSE Dynamic
Works at an Indy in Herts
Post #634243 Thu Jul 13 2023 4:25pm
kosio2001
Hi, thanks for your answer. It was a genuine ring.
Post #634244 Thu Jul 13 2023 7:27pm
cornwall
Hi, I am curious if you resolved this problem, I have a similar situation. thanks
Post #640413 Thu Mar 14 2024 2:53pm
kosio2001
Hi, unfortunately no and I tried everything but the foult is still here. I don't know what to do 🤷🏽‍♂️
Post #640437 Fri Mar 15 2024 6:32pm
ajscheid
South Africa
Any progress on this?
I have a Discovery 4, MY2014 with the same fault code after an engine swap.
Vehicle drives well, might have a slight vibration around 1100rpm but that is it as far as I can tell.
Post #648214 Sun Jun 01 2025 11:05am
Pistnbroke
Have a look at LR time rebuilding the latest engine ...he shows its not as easy as you think to fit it and get it wrong you have the faults you lot are complaining about. Always listen to old people or when they die you will live on in ignorance.
Post #648216 Sun Jun 01 2025 11:26am
