Home > In Car Electronics > 2006 RRS Bluetooth
rik^^
United Kingdom 2006 Range Rover Sport TDV6 SE Adriatic Blue
2006 RRS Bluetooth
Hi All, i understand bluetooth was an optional extra on my year/model. i have had a check and in SDD it does confirm it was a optional i took the back apart and found were its supposed to be but its not there. im happy to buy one but i cannot see any loose cables anywhere to connect it. (only spare connector near it appears to be under the rear seat base)
does anyone know how they are wired in?
(From my understanding it goes to the right of that module)
thanks
Post #648194 Fri May 30 2025 3:10pm
There aren't any spare connectors for the factory options one, (which can be quite a few wires on that year)
I got rid of that useless traffic module TMC (which only seemed to work when tuned to classic FM anyway!)
And fitted a facelift / D4 bluetooth module which are much better, and so much easier to fit.
It connects to that orange optical fibre bus, and 2 power wires, earth and the greeny/blue wire found in the loom below it
You can power it off that red wire if you don't want to touch the loom.
You do need a GAP IID to enable it though. (or SdD)
And some way to answer calls e.g red/green steering wheel buttons or a modified touch screen.
Don't know if you can do it on the headunit. Maybe, probably
https://www.disco3.co.uk/gallery/displayim...&pos=0
Pic here when gallery working......
power connector available on AliExpress
Search for 32 pin connector. Select grey.
https://www.disco3.co.uk/forum/d4-bluetoot...53302.html
Post #648195 Fri May 30 2025 5:47pm
rik^^
Thank you for that andy, ill possibly do that then (i didn't realize that was the TMC module), i should be able to pickup the steering wheel control off of a freelander 2 wheel (it almost the same car)
Post #648211 Sat May 31 2025 7:57pm
