![]() | Home > Faults & Fixes > P049B fault - help needed |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4468 ![]() ![]() ![]() |
Seized flap in the exhaust system, or cracked DPF/blocked LP EGR filter |
Maca83 Member Since: 14 May 2025 Location: Durham Posts: 5 ![]() ![]() |
Canny diagnostics advice that like 👎🏻 |
Can someone translate? |
Those are the possible causes of P049B fault being logged. There's only so much a person can do at the end of a keyboard. A fault code is only there to point you in the right direction (mostly) No diagnostic computer or sensors will tell you whats wrong 99% of the time
But surely there are differential sensors that can tell me whats blocked?? |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1885 ![]() ![]() |
I think Disco_Mikey has explained it very well, and you may not know that he is a very experienced Land Rover repairer. 2023 P440e SE Dynamic on order -cancelled
No, there isn't. I've told you what you need to check. I'm out now |
No problem, appreciate the advice 👍🏻 |
