![]() | Home > General > Is a 2.7 L320 still worth a buy today? |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
You get a lot of vehicle for the money when you buy an L320. If you've got a chance to buy a well-cared for example that has had the usual stuff dealt with as its gone along then it's a decent risk. Be worth investing in a decent smart charger and using it to keep the battery in good shape, especially if it's going to be used infrequently / for shorter trips. A tired battery is the starting point for a number of wild goose chases.
| d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322
Get the water pump done at the same time as the belts, I’ve got a breaker in atm that the guy has the belts done, then a few months later the pump seized and took out the engine.
| AdamH88 Member Since: 29 Apr 2025 Location: East Midlands Posts: 2
Thank you both very much for the comments! |
The TDV8 is a great engine and, frankly, if there is a choice between that and a 2.7, the TDV8 wins every time. 2012 SDV6 - it's missing a couple of cylinders
