Home > General > 2005 Sport SC 4.2 Supercharged
Benji
I'm brand new today to this forum and need advice or tips as I'm considering buying the above vehicle with 120k mileage.
Although I've owned numerous LANDROVERs over the years I've never owned a Rangey, never mind a supercharged one.
What are the things to look for apart from the obvious dash warning lights etc?
I presume this is a fixed 4 x wheel drive with air suspension?
Any advice would be greatly appreciated
Steve
Post #647784 Sun Apr 27 2025 11:03am
Disco_Mikey
At that age, rust and corrosion will be a bigger issue than a warning light on the dash...
Post #647785 Sun Apr 27 2025 12:06pm
d-9
Make sure you’re comfortable with 12mpg
Post #647788 Sun Apr 27 2025 2:24pm
Benji
Where are the areas to look for corrosion? I'm not sure about 12mpg as though a more realistic figure was 17-20mpg?
I'm using it as a second vehicle anyway so won't be used every day
Post #647789 Sun Apr 27 2025 2:55pm
daxmatt
Check ACE pipes, in front OS wheel arch, check ACE bars, listen for knocking from front, for worn wishbone rubbers
Post #647793 Sun Apr 27 2025 6:19pm
d-9
Check sills for corrosion under the plastic covers.
Service history is key, these are very expensive to fix when neglected.
Yes full time 4x4 with locking center and rear diff, air suspension and active anti roll bars (ace). They’re brilliant cars and handle surprisingly well. The only real issue (apart from the running costs) is the ride quality is awful.
Post #647794 Sun Apr 27 2025 8:02pm
Benji
If the ride quality is awful what's the point in buying one then as I thought the Sport was a comfortable SUV?
Does the Vogue TDV8 also have a bad ride, or is it a different animal?
Post #647795 Sun Apr 27 2025 8:41pm
daxmatt
I'd say it a very good ride, and mine has 22s on it, had it for over 10 years
Post #647796 Sun Apr 27 2025 8:42pm
Benji
So two of you are saying the complete opposites. One says it has an awful ride the other says it has a good ride.
Anymore input please from other members?
I suppose the way to find out myself is to test drive the Sport SC and find out personally.
Post #647797 Sun Apr 27 2025 8:55pm
I guess it comes down the tyre size and pressures.
Too high pressure can be bad over speed bumps
Post #647800 Mon Apr 28 2025 4:18am
d-9
Treat drive is definitely the best option, so you can see what it’s like on the roads around you.
Mine is on 275/45/20, at 33f/36r, stock pressure for unloaded but up a profile to improve the ride. It’s fine on smooth tarmac but awful over potholes and degraded road surface. My l494 on 22s rides much better.
The first gen sport was engineered to be…sporty. So the ride is stiffer than the other models at the time - Disco 3 and L322. It was later improved with dynamic (electronically adjustable) dampers and improved a lot on the 2nd gen sport which is around 500kg lighter than the first gen. L322 is definitely squishyer but less sporty to drive.
What’s the point in buying one? They’re a brilliant all rounder.
Post #647802 Mon Apr 28 2025 8:12am
Benji
Thanks for all your replies. Can anyone recommend any Landrover specialist with reasonable labour costs in the Cheshire areas close to Knutsford?
Also, although I had a TD5 many years ago with airbags I've never had a Range Rover so if I decide on the Sport supercharger how does the air suspension work on these?
Are they fully adjustable with different heights and can you make them very low so it's easy to get in before you start up?
Post #647816 Wed Apr 30 2025 5:51am
The ride quality deteriorates with aging of bushes, dampers, etc. When fitted with new bushes (particularly lower wishbones at the front), the ride is much nicer. They don't wallow like a FFRR, a Discovery 3, etc., but they aren't crashy like a sporty estate from the German makers. Well controlled ride with less roll than a FFRR thanks to the hydraulic anti roll bars.
The anti roll bars are a point of failure, sadly, simply because of how they work and the pressures used in the system. A good look around them to see if there is oil/wetness will tell you if they're leaking. Be careful that someone hasn't cleaned the thing first, of course, so have a look after the test drive. As well as the bars, the hoses are prone to corrosion in the driver's wheel arch and getting the correct bits is a PITA. It can be remedied using generic hydraulic bits, however. A search of the forum will show plenty that have done just that. Some will suggest replacing the active bars with standard solid bars, but that will Censored the handling a bit as the vehicle is designed to run with the active bars.
A 2005 is 20 years old so should have 19-20 services in its history. Anything less isn't a full service history as the service interval is mileage or 12 months whichever comes first. Many of them don't get serviced annually, however, so it's not unusual to find one that's been serviced only every 15,000 miles. Not a deal breaker by any stretch but worth bearing in mind.
Check everything works and then check it again. Look for corrosion on the chassis, the tray that holds the fuel tank (under the driver's side), clunks from suspension (drive at walking pace and tap the brake pedal firmly so the nose dips. A clunk indicates the front lower bushes need doing). Check the transfer box goes in to low range and back without any squealing (there is a little noise but it doesn't sound "wrong" if you know what I mean), but bear in mind that very few people ever use low range but it should be checked at each service and thus be free to move. Check the diff lock (select 4x4 info on the screen and put it in low range, rock crawl and ease off the brake. You should see the diff lock symbols on the screen).
Check the tyres for uneven wear - the suspension is adjustable front and rear and if it's out of alignment it can feel a bit pully / wandery on a test drive. I don't like to see cheap tyres on them as I wonder if they also skimp on maintenance. The suspension is air springs which are pretty robust although the air supply system to them is prone to known issues. Check that the suspension raises and lowers properly. If you lower it to access height and then raise it to normal height it should do it reasonably briskly and if you then ask for off road height it'll be slower but should be able to do the whole raise. If you get an error message then that points to a tired compressor. The compressor is noisy in use and lives in a plastic box in front of the near side rear wheel. The compressor is not a life-long component and any RRS with 120k on the clock has either had one changed or is living on borrowed time (or even both). It can be done on the driveway if you're happy with tools.
You can use a OBD scanner to check for error codes but bear in mind that the generic ones don't see all of the ECUs on modern LRs. If you can get it checked by someone with a decent LR specific reader that will give a better check.
Oh, and don't be suckered by the performance in to buying the first one you try. Rolling with laughter
Good luck. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #647820 Wed Apr 30 2025 8:32am
Suspension has an access height (lowered a bit to help getting in/out), normal height which is day-to-day driving, off road height which is raised by approx. 50mm and then an extended mode height which the vehicle will use if it decides it's stuck on something underneath. You can't use this height normally. If this extended mode is used by the vehicle, you can then raise it further by holding the brake pedal down and pushing the raise switch for 3 seconds. This will extend the suspension to whatever is left in the springs.
Kits are available to allow you to have more control of the suspension if you're happy to DIY it.
The L320 (the original RRS) wasn't available with automatic access height (the latter L494 was), but you can select access height using the button each time you park if you wish. Best to select it as you're parking so that it lowers without putting strain on the bushes (if you lower it when the gearbox is in park and the handbrake applied, you can hear it creaking against the bushes.
The system often lowers itself when parked. This is built in to the control system and is usual, although if it lowers a lot then that indicates a possible issue in hiding. You can often check this by pulling the EAS fuse to prevent the system from working overnight and seeing if it sags at one corner - indicates an issue with the air suspension valve block controlling that corner (they sometime get bits of the drying material from the compressor finding its way through and hampering the valve - not unknow and indicates the compressor needs to be overhauled or replaced and the valve block removed and cleaned out (or replaced).
The suspension is fully adjustable for alignment - toe, camber and caster at the front, toe and camber at the rear (from memory). Should be done using something like the Hunter laser alignment ramp. 2012 SDV6 - it's missing a couple of cylinders
Post #647821 Wed Apr 30 2025 8:45am
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Totally agree since getting another L322 v8 sc iv hardly used my sport.
Post #647853 Sat May 03 2025 12:29pm
