![]() | Home > General > New engine: timing belt: recommendation |
| 2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 246
Ok, so the timing belt pulley on one cylinder bank has snapped (heard of this before) and hence the timing has been lost between the cams and crank, so yes same applies as the earlier deduction. They need to remove the cam cover/inlet manifold to have a look at the internal damage (if they haven't already) to give you some idea of a parts list.
| RRSJRM Member Since: 13 Feb 2016 Location: UK Posts: 24 |
You're not the first to suffer from a cracked pulley I believe. Not sure what causes it, I'm sure someone with more experience will chime in. |
Car back, £2.4k later and it runs. There is now a squeak from the starter motor that wasn't there before. There is a slight over rev (only really noticeable when idle and may have pre-existed) and the mechanics note a slight rattle from the engine. I can't hear the rattle, but they do nothing but LR's so I will defer to them. It also seems that the crank slipped one tooth but that is now back in good order. No warning lights.
It's a tough call, you'll never know if you sell it, it could go on for another 100K without a problem, then again, keep it & the crank could snap next week!
I decided that I wasn't comfortable shifting on a car that may have significant issues. I therefore decided I'd live with it for a while to see if it gets a clean bill of health. Well, one week and 150 mile later, it may be dead.
I'd be asking the repairer for a very detailed report of what they did and what the current failure is as no way should it have failed within 150 miles. Sounds to me like they didn't do the job correctly or failed to reassemble it in a workmanship like manner.
I am not overly mechanically minded so even if I did get a report it would be easy to fob me off.
Sounds to me like a injector leaking, the copper washer fails and let's combustion gasses past, hence the rough running. If it is, you have been rewarded as its a cheap and easy fix!
When I pulled over to inspect the car I took the engine cover off and there was small but noticeable smoke coming from the vicinity of the oil cap. Engine was hot at that point having been run for an hour so I didn't investigate further.
Think you're going to be ok, that was blow by gasses you were seeing, take it back to them and ask them to check the injectors on the right hand bank, one will be leaking.
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 324 |
I had the same noise - was an injector seal - As 2RRS says they've probably not used a new seals/washers or the crush nuts that hold the fuel line - easy fix should be no more that £100 to solve. Just need to narrow which injector is leaking you can usually do this by taking the engine cover off and checking for any escaping fuel vapour around each injector or feeling each injector with your finger - you will feel the loose one as it will be tapping/vibrating more. |
Feedback from the garage is that it has dropped a cylinder. Says the noise is from within the engine.
Dropped a cylinder, do they mean dropped a valve? If so, then that's on them as the head would have been machined after the valves are removed in the rebuild process. What is the thoughts on the smoke you could see? From the video you posted that wasn't valve train noise and was definitely injector blow by. I'd get a second opinion as I think they're using your lack of mechanical knowledge to their advantage.
| All times are GMT |
