![]() | Home > General (L494) > Leaking pinion seal on brand new genuine rear diff. |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
There were many diff pinion seals replaced due to a TSB on early L494's as they were assembled incorrectly at the factory causing them to leak. I'd have thought a new diff wouldn't suffer from this fault though. As far as I recall there is a special jig the dealers use for setting the preload, it does cause for the diff to be removed, but yes the seal is replaceable, but then the preload needs to be set.
