![]() | Home > Faults & Fixes > Dreaded whine/noise, possibly diff? |
| Mac35 Member Since: 15 Dec 2023 Location: Angus Posts: 51
Failed differentials, front and rear are not unheard of. Unfortunately if you can hear the noise in the well insulated cabin it's too late for an oil change to help anything. The bearing has already failed if it's loud enough to be heard. |
| 2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 243
I recall that around 2007 there was an issue with the internal casting coating breaking up that then contaminated the bearings and led to failures. If you drain the oil see if there is any Teflon like debris in the oil, if there is then the coating has failed. |
| phazed Member Since: 02 Feb 2025 Location: Dorking Posts: 12
Thanks for responding.
When I had a 2007 L320, I stripped the front diff, wire wheeled all the failed coating out and rebuilt it with new bearings and it was as good as gold. Sold the car with 320k on it and it's still around with near on 450k miles on it. |
Ruddy Nora! I only do about 4K miles a year, nearly all local. I think I will keep using the car until the noise increases and then bite the bullet and get it rebuilt. Any recommendations of who to have the work done by? |
Sorry, can't help on that one. I was doing 50k a year for probably the fist 6 years I owned it. Look up FM07KMX on a vehicle check app, clean pass this year! |
