Home > Technical > 3.6 tdv8 Oil cooler gasket - cooler only
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
I'm having trouble finding a new gasket for the oil cooler, not the entire housing, for a 3.6 tdv8. The complete housing, including filter, cooler and pcv is LR006427 but I just need the gasket for the cooler unit to the housing if anyone knows.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #640925 Thu Apr 04 2024 4:45pm
NoExpert
LR002340 is the part number for just the gasket. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #640931 Fri Apr 05 2024 2:48am
No part number listed for the 'O' ring or gasket, which ever it is for just the cooler part to the filter housing. Just the main gasket as above.
Post #640933 Fri Apr 05 2024 4:14am
Jabba
Thanks guys, seems strange that they don't list the orings for the cooler only, I guess they just want you to buy a complete unit.
Its weird, as you can buy the cooler on its own.
Many thanks
Post #641022 Sun Apr 07 2024 7:43pm
ellzeez
Australia 2007 Range Rover Sport TDV8 SE Atacama Sand
Old thread, but LR002342 is the 3 piece oil cooler gasket set. Have done this job, when I installed a new oil cooler. The diagram only shows 2 gaskets but 3 come with the kit. 2007 L320 RRS TDV8
Post #643709 Mon Aug 12 2024 2:15pm
Jabba
Hi ellzeez, many thanks for the info, much appreciated Thumbs Up 2010 RRS 3.6 TDV8 HSE Galway Green
Post #643710 Mon Aug 12 2024 2:37pm
haydent
Australia
correct
Post #647684 Wed Apr 16 2025 6:05am
