![]() | Home > General > New engine: timing belt: recommendation |
| Notyalc Member Since: 01 Aug 2022 Location: Northumberland Posts: 47
Try MDRS at consett in County Durham. They are sorting these issues all of the time. |
| RRSJRM Member Since: 13 Feb 2016 Location: UK Posts: 24 |
Thanks, I will give them a call. |
| 2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 245
The belt feeds all 4 cams, 2 in each bank, if you're being told it's the drivers side, do they mean the internal chain that runs between thge 2 cams in the cylinder head. Hopefully not too bad as they tend to snap the camshaft cap bolts rather than bend valves, possibly it will have spun the cam lobes as well, so you maybe in for a couple of cams, chain and a tensioner and that's about it. Once it's assessed and you get an idea of cost, I'd be tempted to repair your engine as there are so many poorly built refurbs around that you don't really want to go there. Obviously a nice new JLR supplied exchange engine is the ultimate solution, but at more than the value of a 2015 car it's not a sensible route to take. |
Chances are I am getting belt and chain mixed up as though they are interchangable. Definitely sounds like the chain because that matches the description of only working half the engine. Apparently they can feel the passenger side still trying to suck in air, but nothing on the driver's side.
It's easy to check if the chain has failed on the drivers side bank, take the oil filler cap off and twist the filler neck (held into the cam cover on a bayonet type fixing, like a light bulb)and it will come out of the cam cover, you can then clearly see the chain and if it has snapped.
That sounds familiar. They did mention that it was 'good' it was this side because they could access/check via the oil cap which I don't think is possible on the passenger side.
They seem to know what they are talking about, hopefully it'll be a set of cap bolts, a couple of cams and a chain assembly at worst.
I've been doing some reading (which I acknowledge upfront may be doing more harm than good) but am I right in thinking that if the pistons have contacted the valves I'm in big trouble, but if not, I might get away with the fix you mention? In which case, is it possible to do some sort of pressure test before stripping the engine to see if the valves are intact? |
Not quite correct, the valves will have hit the pistons without doubt as the engine is what's called an interference design, which means that the valves and pistons occupy the same space in the combustion chamber, but a different times, so a cambelt or chain failure will cause piston to valve contact.
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 321 |
Great info and knowledge from 2RRS OP - I was going to say also check ebay if you can buy a decent 2nd head - should be a few and rebuild with new cams etc - should be £2.5k job - lots of dodgy rebuild engines on ebay now most you only get 3 month warranty. |
| dhallworth Member Since: 13 Aug 2015 Location: Glasgow Posts: 50
Personally, I wouldn't... https://www.fullfatrr.com/forum/post689562.html 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
| Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 147
There’s Henshall Engineering in Macclesfield which is pretty close to you. |
Thanks for the Henshall recommendation. They are about 5 miles from me and I didn't know they existed!
Yep, go with a genuine chain and tensioner assembly as they are not overly expensive, you may get away with one camshaft as the other one should still have been in time as it's driven by the cambelt.
| All times are GMT |
