![]() | Home > General (L494) > What to look out for - 2022 P400e HSE |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
anyone? Merc C220 estate Sport AMG
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1902 ![]() ![]() |
Main issue to look for is a failed HV heater.
Thanks Jimbg. I'll check that out. |
Nick900 Member Since: 11 Mar 2022 Location: Kent Posts: 89 ![]() ![]() |
I think it comes down to 'why'. If you live in a city and plan on doing mostly city driving then it makes sense. The small KW battery I think gives about 20 miles range. Battery will deteriorate so would guess 3-5 year old version will have about 80% charge.
My P400e is still giving 27 to 30 miles electric range after 3 years.
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 143 ![]() ![]() |
Yeah, consider how you will use the car. If the vast majority of your journeys between charging at home are under 30 miles, then go for it. If not, then look at a diesel. When running on petrol, the car will struggle to get 28mpg. My last 3.0 diesel could easily get close to 40mpg.
Thanks for the advice so far, keep it coming please.
I still have the PDF brochure for the Sport when I bought mine in November 2021 if you are interested? 2023 P440e SE Dynamic on order -cancelled
Replied to wrong post Merc C220 estate Sport AMG
Thanks, I found that already. I'm looking at an autobiography 2moro, but even things like Adaptive cruise control is an optional extra and the selling dealer (a BMW dealer) has no idea whether the car has it or not. Same with 360 camera but at least I should be able to find the camera hardware easily enough. Merc C220 estate Sport AMG Merc C220 estate Sport AMG 125 year edition Alfa GT Rover 76 V6 |
OK so the 1st car i looked at has fallen through due to lack of a worthwhile warranty.
SpiderPig Member Since: 13 Mar 2024 Location: Herefordshire Posts: 142 ![]() ![]() |
The build sheet for my 2021 P400e Autobiography doesn't include a mention of the gesture powered tailgate, but I know it's there because ten minutes of foot waggling did manage to raise the tailgate. The build sheet doesn't mention heated washer jets either.
Many thanks for that.
I use the key on my P400e to open and close the boot using the dedicated button on the key, far easier than trying to kick open. 2023 P440e SE Dynamic on order -cancelled
