![]() | Home > In Car Electronics > RANGE ROVER SPORT 2007 FUSE BOX PROBLEM |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
There has been numerous posts about corroded wire joints/splice's in and around the passengers footwell, if you have had water ingress issues in the footwell that could be part of the problem, not saying it is as only a suggestion.
LiamG79 Member Since: 01 Apr 2025 Location: London Posts: 9 ![]() ![]() ![]() |
Thanks for the response. If there’s one thing I didn’t want to have to do, it was go through the wiring, but I guess it can be the only logical explanation as to why these three are not working. I guess I’ve got to pull up the carpet and see what’s what. I’m hopeful that because the wet area was confined to one area if the wires were damaged, they would be in that area and not somewhere hidden. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5133 ![]() ![]() ![]() |
Sometimes you can ignore U codes, it depends what sort of fault you have.
The suspension warning light is on (it is red). The front has dropped to the bump stops and won't move. There are no leaks or problems with the sensors. I went to the car one morning, and it was like this. After running a diagnosis, I only get the U fault codes but can't access the system to try to recalibrate or raise it. After finding the fault with the fuses, one of them (F3) being for the air suspension, my presumption is that is why it won't work. |
F3 will only have power when compressor running
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
A "Lost Comms with RLM" means another module cannot communicate with said RLM
sometimes with a red light, you can jack the car up few inches at front or rear or both (whereever very low), and then turn the igntion on. If the red light has gone, and you only have a yellow, try starting the engine and shut the doors
That's interesting to know because I no longer hear the compressor. Before this issue, I did hear it. There was nothing when I removed the fuse in F3 and tested it with my voltage connector. Is this because, as you say, there will be no power going to it at all unless the compressor is running? The other codes say the same as yours: heated windows; even with the engine running, I get nothing. Is there a way to test if the compressor is knackered and I need a new one? |
Unlikely to be the compressor in this case.
When I go to access the air suspension setting this is all I get. I also took it to a friends garage who deals with Range Rovers and his diagnostic tool couldn't even connect. I'll add a couple of photos so you can see the U codes thrown up. |
I have tried uploadind pictures but they are not showing. |
My code reader cannot speak to the suspension ECU. When I try to access it, it keeps saying "communication error with ECU." Confirm whether the diagnostic is connected correctly (it is) and whether the ignition switch is on (it is). I can access everything else on the car. The moment I want to access the suspension features, I get that message. |
In that case, you've an issue with the RLM or associated fuses/wiring etc, which is also why the compressor is not running |
Can we eliminate parts without spending money on a replacement when it doesn't need it? For example, the compressor. Can it be tested to see if a live feed is going to it? If not, it would eliminate that problem and be a wire. Either way, I think this is going to be a pain in my ass working it out. |
