Home > Technical > L320 Active roll control fault.....Help !
Spen17
Bit of a newcomer to Range Rover issues but owning a 2005 4.2sc is proving to be a challenge ! Please bear with me if this all sounds a bit obvious to some.
Currently have a vehicle lean when cornering fault showing on the dash. After scanning with Gap tool there are no suspension faults showing but one Active roll control fault which is C1B14-1C. After checking it would appear to be the lateral accelerometer mounted on the inner sill under the drivers door Part no. RQB 100011. I have checked live value on Gap tool and found this to be 856ft/s when vehicle is stationery. Assuming this to be wrong I replaced it but still get the same result. Can someone please confirm what the values should be at when stationery. Should I be looking elsewhere for this fault ?
Any help would be greatly appreciated. Thanks.
Post #647472 Sat Mar 29 2025 4:02pm
Disco_Mikey
Is the hydraulic pressure reading OK? I ask, as the connectors for the accelerometer and pressure sensor are the same, and can be mixed up
There is also an accelerometer above the front interior light Thumbs Up
Post #647477 Sat Mar 29 2025 6:29pm
Spen17
Thanks for the reply. Fairly sure plugs are not mixed up as the fault has just appeared. However I will check.....assume you are referring to one of the four plugs on the valve block adjacent to the sensor ?
Regarding the pressure check , what live value should I check and what should it read ? Any ideas on the correct values for the accelerometer ?
Appreciate your help
Post #647479 Sat Mar 29 2025 7:08pm
Disco_Mikey
When stationary, the accelerometer should read close to 0
If you still have your original sensor, try swapping it with the internal sensor first, make sure you've replaced the right one
If that makes no difference, you may well have a wiring fault
Post #647481 Sat Mar 29 2025 7:37pm
Spen17
Thanks for the reply. I kind of assumed it should be zero if you are not moving but with these things you can never tell. Thanks for confirming. Still got the original so I can have a look. The wiring is what concerns me. How on earth to track down a breakage between there and I assume its ecu. I have ordered a plug/wiring (plug not serviceable) just in case its that.
Post #647482 Sat Mar 29 2025 8:51pm
alfapat
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I cant for the life of me remember something similar , but check a juction in the inner offside wheel arch foe corrosion , I had a look through old threads that I have posted, but something rings a bell !
Post #647835 Thu May 01 2025 7:20pm
Spen17
A final update on this subject.....After testing everything else I finally traced this fault to the ARC module. when I opened up the module it had an area which was burnt out. After replacing the module all faults cleared and normal operation has been restored. If anyone else experiences this fault showing an accelerometer fault and cant clear it, may well be worth removing your module and checking it for any obvious faults.
Post #648779 Fri Jul 11 2025 8:33am
