![]() | Home > General (L494) > Cooler to Fridge upgrade on 2018 facelift model |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 207 ![]() |
This is good to know, How can you tell the difference from the outside whether its a cooler or fridge ?
Woppyman Member Since: 08 Jul 2015 Location: England Posts: 66 ![]() ![]() ![]() |
Its not easy to identify them. They look identical apart from the internal depth. The easiest way is to press the button on the top. If the only options are 2 blue LED's on or all off then you have the cooler. If when you press the button on the top it cycles through one LED, two LED then off then you have the fridge. Also the fridge has a slight vibration that you can feel if you put your hand on the top of the cubby hole lid. Evoque HSE Dynamic
Do you think it can be retro fitted , are the plugs there ready and waiting |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 562 ![]() ![]() |
